Been having a problem thats come and gone at times but now ive gone thro 2 new belts in 2 weeks! This is driving me nuts now.
Replaced my old bando stock belt after about 12,000km's when it looked to be getting worn down. Scoot had begun to develop an issue going downhill at WOT, would go along fine till i hit around 40-42mph then it bogged a bit and stopped accelerating for a sec, then pick up again and speed up to 45-48mph. Was the exact same feeling you get going downhill on a restricted scoot where it hits 30mph then feels like its being held back only mine does it at 40-42mph, then it "free's" up and lets it go faster again
![Huh ???](https://www.kymcoforum.com/Smileys/default/huh.gif)
This happens for a few weeks or a month or so then it wont go past the restricted feeling at 40-42mph, at this point when i check my belt its normally fraying on tbe inside top edge (inner variator side). Last 5-6 months ive gone thro about 4-5 belts!
Once i swap the belt out the issue goes away for a while and i have no restriction at all, it goes smooth all the way to 45-48mph, then it gradually returns over the next few weeks or months, begining like i said by feeling slightly restricting it at 40-42mph, then not going past 42mph/70kmh, then i know my belt will be frayed and begining to go again
I was on a 1500rpm torque so last weekend i put that down to a 1000rpm to see if that helped any and put in a new belt, stock size. Went for a few days then i felt the dreaded thing began again. Just checked my belt and its begining to fray already, 3 days old, less than 60km on it
![Cry :'(](https://www.kymcoforum.com/Smileys/default/cry.gif)
It must be my variator, my boss, or my rear pulley, cant be anything else can it?
Just refitted my old stock variator, and tried that but its still got that restriction feeling at 40-42mph, so im guessing its prob not the variator. Not sure where to go next?
I dont have any new belts left so i had to fit my old stock bando i keep for emergencies but i need to order a new belt tonight, going Bando this time. 9
My idea is its either in need of a new boss, new variator or rear pulley? Either that or its just down to cheap belts? Still i wouldve expected longer than 2-3 days on even the cheapest, nastiest belts? The longest ive gone has been on my Malossi kevlar which lasted a good few months, all rubber belts i tried have lasted weeks at best. I cant keep buying belts, my old bando did 12,000km for f..ks sake so why are all other belts coming apart so quickly?
Dont want to fit a new bando only for it to fray apart but unless i can find another problem i will need to try it cos my old belt im running on temp just now wont last long so i need to swap it this weekend.
HELP!!!!!!!!
![Cheesy :D](https://www.kymcoforum.com/Smileys/default/cheesy.gif)
