Author Topic: 2 belts in 2 weeks isnt normal at all.  (Read 5379 times)
Re: 2 belts in 2 weeks isnt normal at all.
« Reply #15 on: May 04, 2012, 12:58:22 AM »
my belt its normally fraying on tbe inside top edge (inner variator side).
..can you post a pic of this...
...if it's about 1/16 - 1/8 " inch in, it could be that your belt is grinding against the starter bendix...
..a longer belt will tend to do this....1500 contra helps this....
« Reply #16 on: May 04, 2012, 12:59:35 AM »
...if you run a longer belt, with a restricted driven pulley set, it's definately going to happen...
woodcutter
« Reply #17 on: May 04, 2012, 02:40:24 AM »
I ran kevlar for several thousand kilometers, and never had problems. Why should he avoid kevlar?
i had malossi kevlar 748mm and after 1500km it almost started to fall apart, peaces and 3 or4 teeths was missing along the belt +a lot of sticky dust in cvt casing.
and had some slipping issues when cold. def not for everyday use.
orig. bando i installed 7.000km ago is excellent and there's only 1mm of wear in width
Why cant i run without the bendix tho? It wont damage anything?
i must correct myself ;D. you can but it's more comfortable to use electric starter. it'll hurt nothing  ;D
« Reply #18 on: May 04, 2012, 02:48:04 AM »
...cant run a 748 inna a50, not even with a 1500 contra...
woodcutter
« Reply #19 on: May 04, 2012, 02:52:06 AM »
though, on 748 malossi and multivar, start and mid range was so,so but was getting me off the scale downhill. approx 90+kmh on tacho.
bando 728mm up to 77-78kmh on long downhill. and as I remember there was some grinding noise on 748 but there was no scratching marks at the top of the belt :-\
« Reply #20 on: May 04, 2012, 02:56:06 AM »
..4ts cant turn enough rpms to benefit from a 748...
..belt "flops" around too much...
..736 is about the max, and now, that might even be questionable...
woodcutter
« Reply #21 on: May 04, 2012, 02:58:18 AM »
I did with malossi multivar with white torque spring but somethig wasn't right though it's only 20mm longer than stock.
but top speed was great  ;D
rubber bando 737mm long is the most reliable and compatible I ran in ag50 also on white torque and 5.8gramm rollers
woodcutter
« Reply #22 on: May 04, 2012, 03:02:17 AM »
can be controled with roller weight and torque spring
« Reply #23 on: May 04, 2012, 03:04:18 AM »
....   >poof<    ....
woodcutter
« Reply #24 on: May 04, 2012, 03:09:19 AM »
it was good while it lasted  ;D
now I'm back on stock agility and yamaha x-max 250i  ;D
« Last Edit: May 04, 2012, 03:11:04 AM by woodcutter »
streido
« Reply #25 on: May 04, 2012, 07:23:32 AM »
Wordslinger,
My rear pulley is def not restricted so thats not an issue.  :)
I am 99.999999999999999998% positive its the belt hitting tbe bendix, poss even 99.999999999999999999%
 sure in fact.  :D
Even 729mm long belts are hitting the bendix now if its in  ???
I will post a pic or 2 later tonight, i can see obvious scores on tbe top of my belt surface(where the writing is) and also on the very top edge maybe about 1/2 to 1mm of the inside edge(the edge tbe sits under the bendix) it begins to fray quickly or even rips or tears  :o I had put this down to sh**ty belts but now i realise its been the bendix all along, not tbe belts  :-[
Its early fri morn here and im just up and in work now ( work? Maybe that should be at "work" lol, i got the friday feeling so doing sweet F all today, finish at 12:30 lunchtime tho :)
Ran to work fine this morn on no bendix, speed up 5mph from yesterday, no restricted holding back feeling at all at 40-42mph like i had before and im still on the same belt that yesterday wasnt right, all i did different was to remove the bendix, so it must be that.
I liked my Malossi Kevlar but i doubt a new one will last anywhere near as long as a decent quality rubber equivelent, i may end up buying one temp for now tho if i cant find exactly the same size in rubber. Need to check my Malossi chart later to confirm but im pretty sure it was 736 or 737 - 17 - 30 kevlar belt i was running before, that was great on my 1500rpm torque spring and 5.5g rollers, best set up i ever had sp far.
Ill post those pics for you to see, on my phone just now so need wait till i get home and send them from my P.C cks im sure i deleted them off my phone once i sent them to the computer.
Cheers guys  :)
btw how long do you think it will take me to NOT jump on the scoot and press the electric starter?  :D I did it this morn when i 1st started her up, then again when i stopped at an ATM, then again when i stopped at a shop for breakfast lol. Then i have to get back off and kick start it over. Been so long since i used my kickstart i almost forgot it was there  :D
Chaos is my co-pilot.
streido
« Reply #27 on: May 04, 2012, 07:50:48 AM »
http://www.monsterscooterparts.com/748-18-28-malossi-kevlar-scooter-cvt-belt.html
http://www.monsterscooterparts.com/748-18-28-50cc-gates-scooter-cvt-belt-for-kymco-agility-50.html
Dont want to go as long as those Woodcutter, thanks for the effort tho bro.
736-737 is good for me.
Im in Scotland, not the USA, so i can get a Malossi no probs here, delivered in a day or 2, guess it would be at least 2wks delivery from tbe US to here, if it didnt get lost in transit  ::)
woodcutter
woodcutter
« Reply #29 on: May 04, 2012, 08:09:01 AM »
it's for wordslinger ;D
here 748 is for agility50
