Author Topic: nearly time to get the parts!!  (Read 11690 times)
Re: nearly time to get the parts!!
« Reply #15 on: May 06, 2012, 12:56:54 AM »
...i cant take the PB aroma...
..i use Knocker-Loose!!...
« Reply #16 on: May 06, 2012, 05:01:53 AM »
Baby oil in a spritz bottle. Any light weight oil is fine
baddi
« Reply #17 on: May 06, 2012, 07:32:18 AM »
... Why would you want to use a smaller carb?
The original is made for the 80ccm motor, and this is why it is 20mm :)
whiteknight
  • ..Knight Tweed..
« Reply #18 on: May 06, 2012, 12:55:08 PM »
hmmm didnt know that then again i could go for one thats bigger still. either way i want to get rid of the old one. just had a flick through the service manual and it says venturi dia mm 20, but then i heard on the newer Agilitys they put a smaller Dia Carb on.....f***ed if i know.. :-\
baddi
« Reply #19 on: May 06, 2012, 05:44:07 PM »
I'll measure my carbs the next time im able to then, but i'm pretty sure that both my 2008 and my 2010 are near to identical, because the only diffrence i've been able to find are some markings in the bottom of the swimmer housing. :)
« Reply #20 on: May 06, 2012, 09:46:06 PM »
The carbs they install oem are 19mm. I used a 20mm of the same type. Just a silly little mm longer
whiteknight
  • ..Knight Tweed..
« Reply #21 on: May 07, 2012, 12:39:43 AM »
might just go for a larger carb and de-restrict the exhaust and plonk a open air filter on it, then play with jet sizes untill i get it runnin proper.
« Reply #22 on: May 07, 2012, 12:42:05 AM »
That's what we do!
whiteknight
  • ..Knight Tweed..
« Reply #23 on: May 07, 2012, 12:45:37 AM »
see im not the noob i used to be, im getting to know things now and what to do.
« Reply #24 on: May 07, 2012, 12:59:08 AM »
...my 08 carb has a 18mm venturi...i measured it...
whiteknight
  • ..Knight Tweed..
« Reply #25 on: May 07, 2012, 01:04:49 AM »
thats what albert said to me. either way i'll just get a big arse carb and fettle the zuast and slap the open filter on there...not forgetting the re-jet
« Reply #26 on: May 07, 2012, 01:11:04 AM »
Too big is a no no on 4t's you will lose low end torque if you go over 20mm. It's like sucking the air out of a room using a sewer pipe vs a straw. There is no velocity. A smaller carb has more velocity, and pulls a better charge from the jets. Anywhere from 19-22mm is good depending on the pipe.
whiteknight
  • ..Knight Tweed..
« Reply #27 on: May 07, 2012, 01:20:28 AM »
well i can either go with the 18.5 mm naraku carb or a motoforce racing 19mm carb.
« Reply #28 on: May 07, 2012, 01:22:25 AM »
...i ran a 20mm cvk on my a50 for a while...loved it!!!
..then i started having issues..and swapped it out with oem...carb was not the problem, but a clogged exhaust..
..i left the bowl open on the 20mm, and the rubber seal shrunk so much that i couldnt get it to fit in the grooves...
..never did get a replacement.....
