Author Topic: spark plug  (Read 1004 times)
stevenk24
spark plug
« on: May 08, 2012, 02:33:37 PM »
would my spark plug be a reason for lack of power ???
whiteknight
  • ..Knight Tweed..
Re: spark plug
« Reply #1 on: May 08, 2012, 02:58:29 PM »
that depends, if the spark plug is fouled or not, connections from the ht lead but it could also be compression issues or a simple case of valve clearances. i would personally check the valves first, they should be set at 0.04mm  do this first and see how you go, usually any loss of power is from incorectly set valves its the most common thing around. so get those checked out, if you still have problems then you might want to check your plug and/or do a compression test. not really alot more i can say.....have you rejetted the carb just out of curiosity? because i assume you have derestricted it. anyway sorry im rambling hope you get it sorted
safe riding
stevenk24
Re: spark plug
« Reply #2 on: May 08, 2012, 03:04:51 PM »
how would you check that ???
