Author Topic: speed needed  (Read 3149 times)
stevenk24
speed needed
« on: May 13, 2012, 09:58:54 PM »
mine gose 43 done cdi and drive boss i think it was done but i want more speed any help ??
Re: speed needed
« Reply #1 on: May 13, 2012, 10:13:36 PM »
Read thru Every Thing Wordslinger posted from 3 years ago on. Tuning the cvt is your next big improvement area. Contra spring (1500), and a Good Var will get you close to 50 if everything else is working well. Not much more than that to be had actually. 50 is a doable goal on the agility.
juice
Re: speed needed
« Reply #2 on: May 13, 2012, 11:05:11 PM »
You have NEVER been even slightly satisfied with your a50 , and I don't think you would be if you were able to attain 50mph . So if you need more speed get a larger machine , JMO .
Re: speed needed
« Reply #3 on: May 13, 2012, 11:06:08 PM »
mine did do 43 now it struggles to get there. after time everything wears out and the scoot well get slower. only thing I can do now is get the big clutch spring. and keep up on the rollers.
Re: speed needed
« Reply #4 on: May 15, 2012, 03:18:24 AM »
..dang....that's gonna take a while.....
..start with 40lbs of air in your tires..adjust your valves to .04mm
..yank that airbox off your scoot, and put on a K&N filter...
..get ready to pull your hair out as you jet and re-jet and modify your needle and it's retaining clip, cause you really need to do that for good mid-throttle...and buy a bunch of plugs..
..skip the blown-air induction, unless you're adventurous...   8)
..and dont even read the exhaust mod stuff....
..change the oil...put inna malossi multivar with 5.5grams or less..yup, a 1500 contra and some 1000 flys...
..from there...well, who really knows??
Re: speed needed
« Reply #5 on: May 15, 2012, 06:26:05 AM »
Man... Three years of Ag posts put into three paragraphs. I guess there is a lot of wasted space...
My ZX sh** would be...
Don't bother brother!
3 words.
Re: speed needed
« Reply #6 on: May 15, 2012, 01:44:37 PM »
3 words.
  3 words well do.................GET BIGGER SCOOT.......................
Re: speed needed
« Reply #7 on: May 16, 2012, 01:07:35 AM »
Get NEWER Scoot... I have parts from Every F'n country EXCEPT USA/Russia.
It takes WEEKS to get spark plugs!
Taiwan: Engine case/frame/wheels/suspension/spark plugs
Italy: Cylinder/tires/fork springs/bushings/gear sets/rollers/clutch/Ign coil
Japan: Piston/bearings/varaitor/torque drive set/2 pipes
Philippines: 1 pipe
USA: MSD cdi
China? All their sh** is in the trash.
thebatman
Re: speed needed
« Reply #8 on: May 16, 2012, 01:11:29 AM »
Dam,, what plugs you buying?
I run down to the local Napa Auto parts and by my mines.............usually. (they were out for a cpl weeks)
"THE BAT"MAN...
Says:
Re: speed needed
« Reply #9 on: May 16, 2012, 01:21:13 AM »
NGK BR9HSA  They are not sold in the US. I can't figure why? I have to get them from Jiangwayne...24.95 for six shipped.
Re: speed needed
« Reply #10 on: May 16, 2012, 01:29:48 AM »
..i know.....advance auto never heard of'm...not in their database...
thebatman
Re: speed needed
« Reply #11 on: May 16, 2012, 01:32:30 AM »
I need to go look at the last i bought. I'd SWEAR i bought those..... unless it's the HS i had gotten and not the HSA..
Dam, what did i do wit em?...hmmmm....
OOPS.... My bad... yep, mine are the HS bought local
"THE BAT"MAN...
Says:
Re: speed needed
« Reply #12 on: May 16, 2012, 01:38:51 AM »
YUP! The HS is a standard Outboard plug...
Re: speed needed
« Reply #13 on: May 16, 2012, 01:47:14 AM »
...the hs is shorter...more ccs!!...lmao...
baddi
Re: speed needed
« Reply #14 on: May 16, 2012, 09:23:47 AM »
The displacement is the same, but the compression is lower, when there are more room in the combustion chamber. :D
