Author Topic: my new super 8 150 scoot!  (Read 7268 times)
super8_wv
Re: my new super 8 150 scoot!
« Reply #15 on: June 08, 2012, 04:19:37 PM »
Ditch the riding gear... It's like camo! You are sooooo blended in with the bike I would think it was parked.
Perhaps, I like my fly racing jacket other than the craptastic liner it feels like a garbage bag to me but I guess it kinda does the job, I would love to find a slightly insulated liner for it for those cool mornings but I have had no luck so far. I have been wearing a hoodie underneath in the mornings to compensate.
« Reply #16 on: June 15, 2012, 09:04:43 PM »
I am currently trying to find some armored gear. That stuff is so expensive it almost is silly!
« Reply #17 on: June 16, 2012, 03:00:10 AM »
Maybe some martial arts gear would do. Shin guards, arm guards, elbow guards, etc.
« Reply #18 on: June 16, 2012, 04:13:08 AM »
So it would be like a big line of martial arts sh** leading to my twitching pile of broken bones. Nope.
Maybe a football costume? 008 can be my cheerleader...
« Reply #19 on: June 16, 2012, 05:45:43 AM »
this?...
« Reply #20 on: June 16, 2012, 06:27:42 AM »
I was thinking more like Kevlar/armored elbows, and shoulders. Pants done with knees, and ankles. That blow up job is fine for a boat but I really don't want to bounce any more that I want to grind off my skin.
I'll find something... Maybe second hand.
Wiz
« Reply #21 on: June 16, 2012, 06:38:05 AM »
I got this armored jacket http://www.webbikeworld.com/r3/teknic/freestyle-jacket/ for under $50 a few years back (I think it was $45 plus shipping but its been a while) at http://www.motorcyclegear.com/ (formerly newenough.com)
You can find great deals in their closeouts http://www.motorcyclegear.com/street/closeouts/
I own 3 jackets and 3 helmets 3 pairs of gloves and 2 pairs of overpants because I couldn't pass up on the deals they have.
Current Rides: Can-Am Ryker Rally 900cc, Gold 2012 People GTI 300.
« Reply #22 on: June 16, 2012, 06:45:58 AM »
« Reply #23 on: June 17, 2012, 07:43:33 AM »
Now thats what I had in mind... Thank you gentlemen.
sentinex
« Reply #24 on: June 18, 2012, 04:14:45 PM »
One very necessary mod is to get rid of those incompetent glass fuses and replace them with automotive ATC blade fuses. Blade fuses won't loosen and heat up or corrode.
at the left are the original glass fuse holders, the blue ones at the right are the ATC fuse holders.
Vivo could you maybe do a step by step pictogram of how did you replace them? I would love to do that mod!
« Reply #25 on: June 19, 2012, 03:31:35 AM »
I guess I can't take pictures anymore cause its done. However, here's a step by step instruction:
Things you will need:
1. A soldering iron and soldering lead.
2. Plier cutters
3. This is another alternative ATC blade fuse box or fuse holder
This is just to show you but I will not recommend this because the wire connections on these are using screws. Screws loosen, and a loose connection causes overheating and eventually a melted holder or fire.
Get 3 of these ... These are more weather proof.
4. You will need heat shrink tubes. Get the ones that will fit the wires just fine
Heat shrink tubes will be used to cover the soldered/connected bare wires like in this example
below.
5. Don't forget to buy ATC fuses with same rating as your original glass fuses.
Procedure:
    DISCONNECT AND REMOVE THE BATTERY...
1. Cut the wires of the original glass fuse just near the tip of the fuse holder. This way you have a longer wire left to work on. Do this one fuse holder at a time.
2. Strip/splice the wire. Both ends.
3. Strip/splice the wire of the fuse holder..
4. Cut a generous length of a heat shrink tube and and insert wire in the tube.
4. Twist the exposed wires together and solder them good. There's no worry about sparks or polarity here because you're working on the positive side only.
5. Position the heat shrink tube  centering the soldered part of the wire at the middle of the tube.
6. Get a butane torch or a butane cigarette lighter and run a flame on the heat shrink tube.
    (The tube will just shrink and will not burn)
7. Continue heating the tube until tube is tight on the wire.
8. Repeat procedure on the other 2 fuse holders.
9. Attach the blade fuses.
10. Put battery back...and the hard part...  Set the clock... ;)
Hope this helps...
Just keep in mind that you're just replacing the glass fuse holder with a different type. Not really a major conversion.
« Last Edit: June 19, 2012, 03:35:27 AM by Vivo »
« Reply #26 on: June 19, 2012, 03:42:18 AM »
Clap! Clap!
« Reply #27 on: June 19, 2012, 03:43:49 AM »
Wiz
« Reply #29 on: June 20, 2012, 01:00:07 AM »
"all attached to a mesh shirt thing. "
I'll try bubble wrap...
