Ok Zombie, here's what i have so far.
Found that the cdi ground wire for the pickup from the coil had no ground.
Traced the wire itself back thru the harness to the kill switch. Pulled the kill switch and check the continuity thru the kill switch connector and it read open, even though the switch was in the on position.
After wasting some time searching for a needle to short the wires together b4 the switch to check continuity, I decided to just cut the wires about 2 inchs or so back from the switch, stripped them and twisted them together, and tested continuity, test was good.
Sooo, i connected the switch back to the harness and checked the ground for the pickup at the cdi, and i now have a ground at the cdi for the pickup, but still have no spark. Swapped out cdi, both are new, no spark, swapped out the coil, swapped out the stator, no spark. To be continued........
