Author Topic: Tightening Mirror on 2009 Super 8  (Read 2205 times)
mrscooter
« on: May 16, 2012, 07:36:44 PM »
It sounds simple enough, but I can't figure out how to tighten the right mirror on my super 8 to keep it from drooping (it's tight at the handlebars).
There's something below the mirror, like a collar, that spins around, but won't tighten. If that's a bad sign, any idea where to get an exact replacement mirror? Thanks!
tjupille
Re: Tightening Mirror on 2009 Super 8
« Reply #1 on: May 16, 2012, 10:22:30 PM »
If you're talking about where the mirror joins the stalk, I don't think that's adjustable. You could try sliding that rubber collar off and seeing if the ball joint underneath has a nut to tighten it, but as I said, I don't think it can be tweaked. If you don't insist on an exact fit, there are generic replacements available for 25 bucks or so (http://www.scrappydogscooters.com/COMMON_PARTS.html). There are a lot on ebay starting around $16.
« Reply #2 on: May 17, 2012, 01:51:16 AM »
I have the same problem with the right mirror of my s8. I don't like replacement mirrors, instead I'm considering stock mirrors of other motorcycle/scooter brands. This is a stock mirror of a local kawasaki motorbike that looks nice.
mrscooter
« Reply #3 on: May 19, 2012, 03:17:25 AM »
Thanks. I'm temporarily using strong tape, and might even try to use a liquid metal epoxy. If that doesn't work, I'll look into new mirrors like you suggest, unless there's a way to find exact replacements. Be well and thanks to both of you!!!
Keep the shiny side up and the sticky side down!
Michael
« Reply #4 on: May 19, 2012, 03:22:55 AM »
Why not try Goop instead of epoxy. Goop is somewhat flexible and can absorb vibrations.
alandok85
« Reply #5 on: May 21, 2012, 06:25:38 AM »
You mean that rubber boot thingy? I just put some silicone glue on mine never got attitude from it again.
« Reply #6 on: May 21, 2012, 06:39:00 AM »
Yup! same purpose..
