Author Topic: kymco Agility 50 acceleration  (Read 2835 times)
scooterman11
« on: May 17, 2012, 05:28:04 PM »
I have had my agility 50 since it was new in 2008
It overall is a great bike I just want to now what i can do to get it to get up to speed quicker, as of now i upgraded the roller weights to dr pulley sliders that seemed to help a tiny bit, I also have a leo vince stainless exhaust for it, that also helps alittle also, but i need a bigger jet to get along with the pipe
any help or suggestions to help me get her goin better
is greatly appreciated.
OregonDad
Re: kymco Agility 50 acceleration
« Reply #1 on: May 17, 2012, 07:45:38 PM »
Replace the stock clutch springs with 1500RPM
Replace the stock clutch torque spring with a 1500RPM
« Reply #2 on: May 17, 2012, 11:05:51 PM »
...way to go dad!!!!
        ;D :o ;D
« Reply #3 on: May 17, 2012, 11:10:12 PM »
..what weight are the sliders??
..i'm assuming you've done the cdi and drive boss??
..pipes dont really benefit a 4t very much, but a free-flow air filter will, along with carb jetting...
woodcutter
« Reply #4 on: May 17, 2012, 11:20:00 PM »
also, you can service clutch: clean it up thoroughly, use sandpaper on pads and bell and put some high resistance grease inside drive torque and bearings. it makes a big difference on take up and smoothens up acceleration
replace movable drive face guides(three plastic parts) if it's worn and polish variator pulleys touching belt, with small grade sandpaper also. clean with brake cleaner everything of course :-)
replace belt if it's worn
that's without additional tunning but you can use harder torque spring and clutch sprins as oregondad said but you must sync variator
+ high quality synthetic engine and final reduction oil can help and keep recommended tyre pressure
« Reply #5 on: May 17, 2012, 11:21:22 PM »
..how many kms on your scoot, and have you ever adjusted the valves??
streido
« Reply #6 on: May 18, 2012, 12:00:01 AM »
If the sliders are still stock weight, 6.5g,  then go to 5.5g. I used them for ages now and swear by them, anything heavier and my scoot loses acceleration to the point i cant enjoy riding it. Waiting for 5.1g rollers and a couple of other bit i ordered arriving from SIP in Germany hopefully tomorrow so i plan on trying them out soon as they arrive.
Chaos is my co-pilot.
« Reply #7 on: May 18, 2012, 12:04:21 AM »
..you will like those, bro....
whiteknight
  • ..Knight Tweed..
« Reply #8 on: May 18, 2012, 12:54:21 AM »
i cant even remember what roller weights i put in when i derestricted her??? i think i put the lighter of the two in there, will sling the heavier ones in it on saturday.
