Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
bestem 2012 top box
Topic: bestem 2012 top box (Read 1705 times)
Beatlenut
Newbie
bestem 2012 top box
May 17, 2012, 05:58:21 PM »
Just got my DT, and love it,and added a new Bestem 2012 topbox!!!! Not sure which wire goes where, could I get some help?
Thank u
bdrannik
Full Member
Southwest Florida USA
Re: bestem 2012 top box
May 18, 2012, 12:57:12 AM »
Kymco DT300 wiring colors for your box:
Green - Ground
Brown - Tail Light
Green w/Yellow stripe - Brake Light
The wiring harness for the tail is in a light blue plastic sleeve/cover and has a green square plug on it - please excuse the bad quality photo:
Try to make your wiring connections in this small harness (between the green plug and the lights) instead of the main chassis harness. If you damage this small tail harness it is available from Kymco:
Good luck,
Brent
2011 DT300i - Givi Windshield - HID 5K Low/High Beams - LED Tail/Turn/License Bulbs - Front signal mirrors converted to running lights/signal - Dummy bulbs to LED 5K white running light/amber signals - Givi E55 w/Admore LED Kit & custom paint - Scorpio SR-i900 Alarm - NGK CR7EIX - Amsoil Synthetics
Beatlenut
Newbie
May 18, 2012, 07:49:59 PM »
Thank so much for the info. , I got it wired up
And it works great.
Thank u
Back
