Author Topic: 2007 Agility 125 Question  (Read 2035 times)
chadbraun
« on: May 18, 2012, 04:12:35 AM »
I recently bought a 2007 Agility 125 from a friend of mine. I had to take it to the shop to get it running again. My question now is that I have been reading post that people can get their scooters going 65mph. I have been riding my scooter to work now for a while and I can only get mine top speed of 40-45mph. I am wondering if anyone has any ideas of what I could do to try and figure out why it isnt going as fast as it should. It sounds like it is running fine and I am 180 lbs so it should be going faster but I have no idea. Any ideas? Thanks
Re: 2007 Agility 125 Question
« Reply #1 on: May 18, 2012, 04:47:23 AM »
Air in the tires. GOOD tires... Do you have access to a multi meter with a tach function? That will help to tell where the issue is. Also do a compression test. It has to be over 120psi to run well. You could have cvt wear ie belt/rollers sticking pulleys. Try to get some numbers posted, and we will figure it out.
New plug, fuel/air filters go a long way too
rxrunner
    • Kymco Agility 125
« Reply #2 on: May 22, 2012, 06:36:43 AM »
Just as an FYI. I just bought a 2007 Agility 125 a couple weeks ago. I had the compression tested by a mechanic and the compression test scored 125. The scoot is stock and I have taken it close to 65 indicated (so close to 60).
« Reply #3 on: May 22, 2012, 09:59:26 PM »
The compression is on the low side but should be ok. We still need rpm's to know where the issue may be. Worn belt/rollers are always # 2 suspect.
dBuster2009
« Reply #4 on: May 24, 2012, 03:42:22 PM »
This may sound like a silly question but a top end of 40 to 45mph sounds more like an Agility 50...  Are you sure it is actually a 125cc bike?  The plastics and decals are interchangeable.  Also did a PO (Previous Owner) drop in the internals of a 50cc into the bike?
All of these could also be a factor.... ???
Kymco Agility 125
Yamaha XS850G
PassedByAScooter
« Reply #5 on: May 24, 2012, 08:06:26 PM »
I'm 210 - 215 depending on how many donuts I just ate, and can get 60-62mph registered on the speedometer easily. It's a great, torquey scoot!
If all is found to be normal, placing in some sliders/rollers and other higher end aftermarket parts will help. Example: On my Yager I could get 67 on a nice flat surface. Swapped out the rollers for some sliders and I'm hitting 71-73 with more power through the entire band.
Please keep us posted!
2010 Kymco Yager
2009 Kymco Agility 125
MrKymco
« Reply #6 on: June 05, 2012, 11:58:17 PM »
Old tread but always like to give info for readers.
I weighed  myself today and am 248lbs in clothes and jacket. I carry a backpack of around 5 pounds including a disc lock. So, just over 250 pounds and the Agility 125 reaches 65mph+ at WOT fairly readily under good conditions. Speedo is off by around 10% across the power band .
Acceleration is good  and passing power adequate. Overall I find it to be a fairly punchy little engine.
scoots!
