Does the Yager check air density coming in between the air filter and injector? If it does won't burn it up without the filter is it changes for density. Now this depends o if the ECU adjusts for oxygen etc, but if it only adjusts for exhaust O2, then it could be a problem.
Glad to hear you have it running well, still need to check it all out.
