Today while i was getting the panels ready for install i took her for a teast ride.
Take-off was great, she fell out of the power-band. shot down to like 6g's. I had 7g rollers, went to 6.5's...
At the moment she has oem var--oem clutch--Malossi green contra w/5g rollers(actually 30.6 gram).
Take-off lags now but she stays in the band..
I have a Malossi purple contra, should have some clutch springs to swap. The hills seem good right now. she kept a good 8g's going up the hill i did
The carb is off of course..
Has the OEM 82mj--35pj, mix @ 1 out, stock air-box.
She is rich for some reason... Yes Word i thought about you and checked the oil pump setting..
I have a pipe on it, you would think it would lighten the plug, not be that rich OEM for sure.
I cut open the plug to really see it. Showed it to WORD earlier as well. HEre is that plug.....
Looks pretty rich for OEM huh?..(the mix was @ 1-1/2 at the pic time)
This could/maybe/possibly explain bit of the lagging i do feel. Maybe she getting TOOO rich and lagging.
I was nervous about the jetting since word is at a 117 atm.(oem is 82) My jets are always smaller than his of course since i am at a 2225 ft above sea level.
I never can remember about the direction of a fuel screw. WORD did advise me today that it is clock-wise to lean.. I may NEED to install the open filter so it will lean out a bit.
SOOOOO odd that word was getting odd readings with the next-r pipe and this sh** is to rich..
Let's get some feed-back and get this thread popping.
Thanks guys.......
YES i will finally stop posting and shut the fk up.
