What's really going on guys?
This a.m i went and installed an open air filter on the Haze. She did not like that at all. :'(
She bogged down good, wanted to die of kindof. I had the mix screw all over the place, to 3 out, hoping it would correct but wouldn't. I guess that means she is to lean with the open filter. I would have thought i had PLENTY of room to lean out.
I re-installed the box and took her out past my lil 1 red-light town on a real maiden voyage..
I did keep the throttle between 1/2-3/4.... for the most part. I did have a spurt to try it.
At 1/4 throttle she seems to "spit" to much.
I had no problem hitting 10g's with no more than 3/4 as well. I made 2 short vids of pieces of the action.
I was way impressed with the "OEM" S9. When i done my black s9 it went straight to a used kit.
The cvt isn't right. Wants to drop "gear" at take-off but quickly hits it, has a loooooong, strong, and pulling "2nd"..... when she hits "3rd" there is a slack lag down to about 8g's then back up. The pipe seems to be around 8200ISH. NO problem hitting a 53? indicated today. I put just a hair over 100kms today on her..... Of course i have a BUNCH of hills around here too
....She had no problem staying in the band with 1/2 throttle.
She has to be close... HAS TO BE..... Where is the key?
I know now that the A.C. frame is 18mm lower, 6mm narrower, and 6mm longer than the L.C. frame.You can tell the difference between the 2. Had no idea till after i got her put together.
Of course i took a cpl more pics today as well on the 1st ride out.
To be so dam ugly that sure is one fine looking scoot..LMAO
I'll post the vid. Hope it has sound...
