Author Topic: Purple Haze....all in my brain  (Read 28069 times)
Re: Purple Haze....all in my brain
« Reply #60 on: May 21, 2012, 05:12:35 AM »
It will help to grind off the point from your drill bits. That is if you are going to drill out the boss for a collar. Leave just the cutting edge to get the hole, and do it in 3-4 steps so you really can't mess it up. I use wet sand bags for odd shaped stuff with a level across the top surface. You can bed your part in the sand bag, and it will stay pretty well. Just go easy like a surgeon.
Shaka
« Reply #61 on: May 21, 2012, 05:23:52 AM »
Quote
There's the key!!!!
thebatman
« Reply #62 on: May 23, 2012, 09:01:44 PM »
I'm finally getting outta NC mid next week.
It's finally happening huh?..  :(
Gonna hate to see you leave N.C. but sometimes things like that happen.  ;)
But dam, aren't you moving to constant rain? ...  :D
Dam sure hope to still have contact regardless of the state.  ;)  :D
There's the key!!!!
You guys have me thinking....... That's some scary thoughts though,
but it may have to be a reality.  :-X
IDK if i'd make a good surgeon.. ;D
"THE BAT"MAN...
Says:
thebatman
« Reply #63 on: May 23, 2012, 09:20:59 PM »
Hey guys, I had a small issue. The water-pump started leaking on me OMW home. I was creeping her ass home.... Luckily i had the w-p from my black S9. Installed that one and changed the cvt.  :-[
I wasn't thinking about it before but i happened to have 2 different belts and went to measure. I can 2nd  THE Word man's post and pics.  ;)
A gates 748x18x28
OEM Bando belt.......Gates IS longer....
I never knew....or paid attention..
I changed the cvt.. Installed an Motrio clutch w/stiff ass flys, Malossi Violet contra w/unrestricted pulley, OEM var. w/LV 5.7g rollers, AND the Gates bel..(used of course)
She revved to 7-8g's BEFORE it would even move. VERY revvy Wouldn't even cross the LR floor with out being at 8g's +... I had asked an opinion  ;) and was stated it was the belt, swap contra out, then see.
I was thinking the flys but i dont know, that's why i asked.  :D
Here is the belt travel i was getting with the looser set-up..........
Not bad but dam sure not great.
Both of the belts i have measure JUST UNDER 17mm.(1's like 16.6..then 16.8)... The drive boss is 38.10mm... The belts may be reaching their limit at this point if they suppose to be 18mm..  :D
I hadn't gotten the chance today to mess with it. Had school today, rained yesterday and today AND suppose to rain tomorrow.  >:(
Going to change contra. (happen to have a slightly used NCY 1500)... May need some 6.5g's,  ???  :-\
"THE BAT"MAN...
Says:
« Reply #64 on: May 23, 2012, 11:23:03 PM »
The high rev's are the fly springs. And I do believe the belt is too worn for full travel. Id leave the contra till you sort out the flys. Then you will see better what the contra is doing
« Reply #65 on: May 24, 2012, 12:01:06 AM »
..i believe the contra to be the determining factor of how to set everything else up in the cvt....
« Reply #66 on: May 24, 2012, 04:31:07 AM »
That is the deciding factor.
thebatman
« Reply #67 on: May 24, 2012, 09:08:43 PM »
What up guys?....
Well, needless to say the cvt has fkn dumbfounded me..
Zombie may have been on to something with those flys... I swapped everything around....Still had a nasty high rev to move.. Tried green contra, purple, and yellow.. Tried 4.5g-6.5g rollers
Settled back to the oem clutch w/Jasil 1500 flys.(still f'n stiff)
Malossi Violet contra w/un-restricted pulley
Bando belt w/4.5g rollers....
I cant tell if they are a tad TOOO light or not. Dam sure shifts smoother than w/5.1g's. Holds rpms' better w/o falling totally out the band.
Belt still didn't arrive at the TOP of the var. Same spot as before.. Could that be the 16.6-.7mm belt width----instead of 18mm when new?...(seen in pic it doesn't lack much ::))
OR IS IT still in the tuning?
I wanna try the gates belt since that's the belt i was using in the black S9.  ???
Maybe i should try it again since i used oem clutch again???????????
Seemed like it was SLLLOOOWWWER at take-off with the gates....
Maybe i shouldn't fine tune.  ;)
I really don't understand how an OEM carb w/OEM box w/OEM jets can be rich.....at all... But if i install the open filter she'll bog down hard
"THE BAT"MAN...
Says:
thebatman
« Reply #68 on: May 24, 2012, 10:24:51 PM »
WHOA....... :o
Just thought about something....
If these belts are 18mm wide and mine reads @ 16.6..
This belt only has right at 6500 KMS on it..  :o  :-[
In my defense, the engine was built...
Dam, my tuning sux. That's a lot of wear for so few miles..
This is the gates 748x18x28 belt.....
"THE BAT"MAN...
Says:
Shaka
« Reply #69 on: May 25, 2012, 12:21:47 AM »
Yep...heading out Sunday morning.  Taking a cross country road trip with my dad.  :-\
It doesn't rain all the time...just most.  ;)
I'll still be around. That's the beauty of the internet!  Just keep in mind I'll be 3 hrs behind you...no early calls please.  ;D
« Reply #70 on: May 25, 2012, 12:59:33 AM »
..yes it sure could!!!
..and i bet that 748 belt is a bit long, witha oem combustion setup...
..i believe you need more hp to run that belt...and a stiffer contra....
thebatman
« Reply #71 on: May 25, 2012, 01:59:54 AM »
I went back to it...
I had to swap clutches again.  :-\
The oem clutch with the Jasil fltys gave me a 6200+ stall.. Bitch would not even consider moving till then. Thats way to much IMO.... THEN i couldn't get the flys back OFF..  :-X
Swapped an old clutch with old flys.
I went back and installed the Gates belt with the weaker set-up.... not bad..
Changed to 4.5g's... a Lot better, held the rpm on hills as well..... Continuious(for the most part) 9g taching.... did seem a hair to revvy sounding... swapped back to 5.1g.. The bitch falls out the band again... some 4.75 woiuld be nice i think.   I ain'ts gots me none of dem boss... :'(
I can get her close but then i install a stiffer contra and all fkn hell breaks loose.  :-[  ???   ::)
I think i'll try the Gates tommorrow and just keep the 5.1's that knock her down..
"THE BAT"MAN...
Says:
Shaka
« Reply #72 on: May 25, 2012, 02:05:24 AM »
A stiffer contra acts similar to lightening the rollers.  If you put a stiffer contra in...increase to roller weight to compensate.
« Reply #73 on: May 25, 2012, 03:29:16 AM »
I had the red Malossi contra, and 9gr Malossi rollers in the Ruima. in a Prodigy Rukus var. Ate belts in a month. I'm glad it blew out...
« Reply #74 on: May 26, 2012, 12:47:37 AM »
..shaka is right on th money...
