Author Topic: Belt size DT300I  (Read 4792 times)
racewalker
Belt size DT300I
« on: May 20, 2012, 07:56:35 PM »
JUst opened up the case to remove the sliders. Found the belt falling apart. I can't find the size anywhere. I will order an OEM belt but want to purchase something to run for now.
08 People S 125
11 Downtown 300i
racewalker
Re: Belt size DT300I
« Reply #1 on: May 20, 2012, 08:03:28 PM »
It was rubbing the case as well on the outside. The sliders were pushing it out to far.
08 People S 125
11 Downtown 300i
Cortez
    • My flickr account
« Reply #2 on: May 20, 2012, 09:07:24 PM »
Holy sh...!  :o
How many miles on that belt and/or how many since you put the sliders in?
'08 FZ6n S2 ABS
de-dee
« Reply #3 on: May 20, 2012, 10:06:43 PM »
the belt size is 1004 mm out side and 25.2 mm wide  30% angle  my belt is 1010mm 24 mm. that is why I have high rpm,s  I think,!!!  I have a new belt  it is 1004 mm. 24 mm. that is why I was inquiring what was proper size ,. but kymco says there is no spec,s  on it I THINK derand motosport ottawa has a belt in stock,.    it took them three months to deliver my belt,. should be better now, I hope, if not I can send you mine,. for your trip,.  joe goulet  golden hawk scoot  I just installed side givi boxes with lights does it ever light up, just like admore,s advertizment,. I will be sending pictures soon,.
de-dee
« Reply #4 on: May 20, 2012, 10:21:25 PM »
can you measure outside dia. if there is enough left of the belt  and the width,
TANWare
« Reply #5 on: May 20, 2012, 11:32:03 PM »
if you were rubbing that badly I would bet it ate into MPG and/or top speed...............
racewalker
« Reply #6 on: May 20, 2012, 11:44:28 PM »
Holy sh...!  :o
19000K. I put the sliders in about a month ago or less, I did 600k last sunday and other than that I do about 100k a day 6 days a week.
08 People S 125
11 Downtown 300i
racewalker
« Reply #7 on: May 20, 2012, 11:48:56 PM »
I thought about it but it may have stretched. I did find one at gearhead.com but will be about 2 weeks.
08 People S 125
11 Downtown 300i
racewalker
« Reply #8 on: May 20, 2012, 11:50:52 PM »
you may have seen my other posts about this lost a lot of top end and gas milage is gone. I just put the rollers back in today.
08 People S 125
11 Downtown 300i
racewalker
« Reply #9 on: May 21, 2012, 01:26:31 AM »
The fleet! If I can't find a belt to work until the oem one gets here, I will insure the people S 125 for a while.
« Last Edit: May 21, 2012, 01:29:57 AM by racewalker »
08 People S 125
11 Downtown 300i
TANWare
« Reply #10 on: May 21, 2012, 11:38:16 AM »
To be pushed that far out something must have gone wrong. I assumethough too this is the first version of the variator. There is a second version that seems with the stock rollers to have ann entirely different RPM profile where the sliders are not required. Don't remember the numbers off hand.
I haven't had an issue with mine as of yet, thankfully (as I search for some wood to knock on). I did seem to drop 2 MPG or so but that I think is the wrist having a bit more fun than before...................
Cortez
    • My flickr account
« Reply #11 on: May 21, 2012, 06:02:23 PM »
LEA7 vs LGE5?
Make sure you report in when you check your belt and/or weights.
I'll be opening mine up at around 5000km (3000 miles or so) at the next oil change.
BTW - the new variator (the one from people) reacts even better to the sliders.
Still waiting for a test ride, but we have a guy here that put 14gr sliders in his People 300.
He's faster off the line then me, faster in every situation imaginable and even his top speed
is higher (100mph indicated).
'08 FZ6n S2 ABS
racewalker
« Reply #12 on: May 21, 2012, 06:46:14 PM »
I am hopping to find something tomorrow locally to use until the oem gets here. I want the oem in for the trip. I will report what is happening as I go. I had 14 g sliders in. I put the origan rollers back in now. I have had sliders on my S 125 for a couple of years with no problem so didn't expect anything like this on the DT.
08 People S 125
11 Downtown 300i
racewalker
« Reply #13 on: May 22, 2012, 02:14:32 AM »
I measured mine on the counter, made a mark on the belt and the counter rolled it to the mark again, marked it on the counter. i measured length to be 970mm width to be 24.0mm. not sure how to measure the angle.
08 People S 125
11 Downtown 300i
duesouth
« Reply #14 on: May 24, 2012, 07:43:56 PM »
Okay, I'm curious. So, you put the new variator (LGE5) in with 14gr sliders? What's his cruising RPM? Is it more revved up?
