The shape of the guide is, that the more linear the guide is, the smoother and faster can the accelleration be. But there will also be transfered more pressure from the torque spring onto the belt, so you will have to have a stronger engine to pull the steeper and more linear guide.
![Smiley :)](https://www.kymcoforum.com/Smileys/default/smiley.gif)
The ball bearing there might give less resistance and the pressure from the touque spring will be more constant, so i think its definately worth trying!
![Wink ;)](https://www.kymcoforum.com/Smileys/default/wink.gif)
