Author Topic: Need Help with CVT Issue...  (Read 12707 times)
Peters
  • In Glock I Trust
Re: Need Help with CVT Issue...
« Reply #60 on: June 08, 2012, 10:44:51 PM »
Will do
Remember, the ppl's engine is way different than the ZX's
*2001 ZX-50 beater
obz
« Reply #61 on: June 09, 2012, 01:47:43 AM »
Do you have a ZX or a People?  I've got a People.
Peters
  • In Glock I Trust
« Reply #62 on: June 09, 2012, 02:35:56 PM »
Both :)
2010 people with BBK and a stock ZX
*2001 ZX-50 beater
Peters
  • In Glock I Trust
« Reply #63 on: June 10, 2012, 11:59:48 PM »
Took the shaft off the pump and reinstalled the pump. O-ring was good. Shaft pulls right out of the pump. Very simple. I already had the inlet and vacuum lines plugged
*2001 ZX-50 beater
« Reply #64 on: June 11, 2012, 03:41:47 AM »
You will be way better off in the long run.
obz
« Reply #65 on: June 11, 2012, 02:23:50 PM »
Did you do that to your people or your ZX?
Peters
  • In Glock I Trust
« Reply #66 on: June 11, 2012, 04:32:25 PM »
The People
*2001 ZX-50 beater
obz
« Reply #67 on: June 11, 2012, 05:07:47 PM »
I'm going to give it a go this weekend.  Seems like a better move.  Is the o-ring plastic or something else?  Since my People is a 2005 I worry that it's going to be all tore up...
« Reply #68 on: June 12, 2012, 03:00:53 AM »
Standard rubber O ring from any auto parts store. About .30 cents.
obz
« Reply #69 on: June 12, 2012, 02:33:43 PM »
Thanks Zombie.  Looks like I know what I'll be doing this weekend.
obz
« Reply #70 on: June 12, 2012, 05:40:29 PM »
Am I cool to leave the oil pump still hooked up without the gear (I mean hooked up to the oil tank)?
« Reply #71 on: June 12, 2012, 11:18:48 PM »
..NO!!...plug all them tubes and ports and stuff!!...tightly!!!
« Reply #72 on: June 13, 2012, 02:09:58 AM »
I agree. Even non spinning the works will get fouled up.
« Reply #73 on: June 13, 2012, 02:17:57 AM »
...i plugged and tucked the tubing...
« Reply #74 on: June 13, 2012, 02:28:27 AM »
Why do you have the cable hooked up? Get a one piece...Maybe when yours wears out... (no jinx)
