Thanks Streido, I'll let you know once it's off!
I have a standard CDI with green connectors and it's marked Kymco and has a part number, the one on the bike has no logo, no part number and white connector, may see if I can get a stock unmolested one in exchange for this!
I've already got the heel panel and an airbox coming, the rest are screws and so on, so will get from a dealer for the right parts if they aren't too expensive, biggest issue is that one bolt holding on the rear grab rail has stripped the boss in the frame (how the hell do you do that!)
The spare main get is labelled as an 80 while the bag it's in is labelled as a 90, so suspect the 90 is in the carb, will change that!
