Author Topic: 2008 kymco agility 50 Hard time running  (Read 4174 times)
scooterman11
« on: May 24, 2012, 07:38:18 PM »
Hey Guys
the other day I put my after market leo vince pipe on my agility, then I had my jets drilled out to proper size
just yesterday it started acting up and would not stay running its really starting to make me mad
what do I do
streido
Re: 2008 kymco agility 50 Hard time running
« Reply #1 on: May 24, 2012, 08:26:52 PM »
What size did you drill out the jet to?
Did you secure the manifold down tight so it doesnt leak? Check its not too tight, i did this once and split the rubber underneath causing an air leak. Scoot ran like crap till i found it.
Chaos is my co-pilot.
scooterman11
« Reply #2 on: May 25, 2012, 05:11:26 PM »
I went down to my local scooter shop which is Lifecycle in kalamazoo and they drill the main out I believe 3 and the pilot 5 i could have what they did mixed up
streido
« Reply #3 on: May 25, 2012, 05:18:00 PM »
Those numbers mean nothing to me ???
3 what? 3mm? Should be 82main on a derestricted Agility, not sure if fitting a leo vince req a larger jet on a 4t ? If it was running good before hand then i would guess it down to the jetting being wrong?
« Reply #4 on: May 25, 2012, 11:48:41 PM »
Its best to just get new jets to the size you need. the pilet jet you dont need to touch.
just the main to a 82 any bigger you well get shoked out. and for the muffler if it dont fit tight you may need the washer that goes in there or spacer.
« Reply #5 on: May 26, 2012, 09:25:18 PM »
..you will need somewhere in the vicinity of a 95 main jet....
..that translates to .95mm
..the 3 and 5 makes no sense...
..aannnd, the thing is, a pipe doesn't greatly increase 4t performance...oem exhaust can handle the addition of a free-flow filter, which will indeed increase performance, with a few other mods....
« Reply #6 on: May 26, 2012, 10:15:55 PM »
wow 95 jet why even put one in lol......
« Reply #7 on: May 26, 2012, 10:18:20 PM »
..you're right, blue...why even??..
..just put the oem exhaust back on, and slap on an air filter!!
..don't waste tyme with th' dumb sh**!!
Kenho21
« Reply #8 on: May 26, 2012, 10:36:57 PM »
Definitely sounds like jetting issue, if they drilled out to 3mm or 4mm, you could just use a funnel instead... I have mine jetted at 1.05mm right now and its waay to rich.
I've looked around for a while to find bits and that can accurately drill jets but they are hard to find. Luckily my neighbor owns a company that manufactures machines specializing in exactly that, drilling super tiny and precise holes in things using electric current. Like in a tomahawk cruise missile turbine lol... he's the most badass mechanical engineer I know.
« Reply #9 on: May 26, 2012, 10:40:30 PM »
..any machining hook-up issa good one...
..where th hell you been, kenho??
..you were here back in th' day...
you and blue are the only two "buddys" i have left, from when i first signed up here??
thebatman
« Reply #10 on: May 26, 2012, 10:43:26 PM »
Took my jet from a "90" to a "87" recently....(think she'd like a "88")
"THE BAT"MAN...
Says:
« Reply #11 on: May 27, 2012, 12:39:41 AM »
I only have a 80 jet in mine. and it does fine. ( dont touch whats not broken.)
thebatman
« Reply #12 on: May 27, 2012, 12:42:38 AM »
That's where i become confused..
I'm at 2225ft. I should use a SMALLER jet than ANYBODY.. ::)......I mean TECHNICALLY, with the denser air altitude,etc....
"THE BAT"MAN...
Says:
« Reply #13 on: May 27, 2012, 12:56:22 AM »
..batman, arent you inna historically "dry" area tho???
..i think i'm like at 700' elevation here....
« Reply #14 on: May 27, 2012, 03:51:20 AM »
It's an historically dry "county". The Air is fine. There is something in the water tho...
