Did regular maint., Scooter has 39000 kilometers, factory speed kit(Pulley bushing and jets).
Scooter started fine for over 3 years,Battery got low. Bought new battery worked fine , then one day it stopped starting with elec. start. Kicks on first kick every time.
Hit start switch and it turns over engine one rev. and stops.Lights get very dim.Sounds like something is binding up.
Tried good used bendix and starter, no difference.Straight wired starter and same thing.
Haven't tried relay or switch replacement yet. If you hit start switch with starter un plugged you hear relay click.
Could the little bushings that go in the side cover and engine that the bendix be worn enough to cause enough play to do this?
These bushings are the only thing I haven't changed.
