Author Topic: jet problem  (Read 3400 times)
franx93
jet problem
« on: April 25, 2009, 01:21:00 PM »
hello, i put in my agility R16 the main jet K82 as office manual. but at 55km/h it don't go over. But, if i close half of air hole (behind air filter) it goes up to 65km/h. is there any method to set the air without increase main jet?
thank you
KymcoFan
Re: jet problem
« Reply #1 on: June 29, 2009, 12:26:54 AM »
Im having a similar problem I think we need to get a new air filter but im not sure noone wants to answer my question I had some asshole mock me on my post it was pretty crappy
Re: jet problem
« Reply #2 on: June 29, 2009, 12:28:07 PM »
mine runs rough only in cold weather ,I would like to learn how to lean out the gas on the carb.or add more.
sticlistul
  • Sex, Scoot and Rock 'n' Roll
Re: jet problem
« Reply #3 on: March 23, 2010, 04:29:23 PM »
thank you
I have same problem with those 55km\h but what does it mean "if i close half of air hole (behind air filter)" i would like to try it and see if speed increase ,but i don't know what franx want to say
Re: jet problem
« Reply #4 on: March 23, 2010, 04:35:27 PM »
thank you
..you really need to increase the main jet size...if you're blocking half of the air flow into the carb to make it run better, then your mixture is probably very lean, and you stand to damage your piston...
Re: jet problem
« Reply #5 on: March 23, 2010, 04:36:04 PM »
..which post, or what is your question??
sticlistul
Re: jet problem
« Reply #6 on: March 23, 2010, 04:46:46 PM »
when you say blocking half of the air flow into the carb you refer at a small screw on the carb ? the one which needs to be at 2 and a half revolution?
Re: jet problem
« Reply #7 on: March 23, 2010, 04:50:46 PM »
..that screw is only for your idle and just off idle mixture...
sticlistul
Re: jet problem
« Reply #8 on: March 23, 2010, 04:58:22 PM »
then how you block half of the air flow ? and from where ? franx says he blocked from behind the air filter ...i dont see nothing there ...
Re: jet problem
« Reply #9 on: March 23, 2010, 05:13:22 PM »
...'m assuming he meant by taping over the hole that ports into the carb...i dunno...lol..
Kimcofan
Re: jet problem
« Reply #10 on: March 23, 2010, 05:30:16 PM »
Hey what was that site you order your jets from wordslinger I am ordering my jet today and forgot the site?
Re: jet problem
« Reply #11 on: March 23, 2010, 05:50:24 PM »
...i buy mine local....i think there's a site called Jets-r-us...or something like that....google that...
Gravzy
Re: jet problem
« Reply #12 on: March 23, 2010, 05:52:58 PM »
i used SIP for mine was good quality and cheap :-)
sticlistul
Re: jet problem
« Reply #13 on: March 23, 2010, 05:53:22 PM »
i am curious how I can block my air filter  to see if it works in my case .
Re: jet problem
« Reply #14 on: March 23, 2010, 05:59:29 PM »
....that's just not a good practice....but it may tell you if you're lean...
