Did you miss your
activation email
Dropped my People 150 2006 and it will not start
Topic: Dropped my People 150 2006 and it will not start (Read 1687 times)
zingzing
Newbie
April 26, 2009, 01:13:51 PM »
If any body can give me some pointers, it must happened to a lot of people. I am new to scooters but I am mechanically inclined and have the tools. I downloaded the manual. The engine will run but when I try to accelerate to take off it dies, in fact it dies at the minumun effort to accelerate.
thank you in advance for your time.
Honkerman
Newbie
Re: Dropped my People 150 2006 and it will not start
April 27, 2009, 02:31:44 AM »
Did you drop it on the left or right side?
Left side is the CVT, which would make sense if knocked something loose in there. Right side has the exhaust, which if the exhaust pipe got bent badly enough...well, you can probably figure that one out.
winginman
Sr. Member
April 29, 2009, 09:50:13 PM »
I would start checking at the airbox and work back to the carburetor checking to see if something got displaced in the drop or is stuck. If that is ok I would start tracing the fuel line to see if it feeds ok. Don't know what if any kind of pickup is in the that could have displaced and caused a kink. Really sounds as if it is not getting enough fuel.
And as Honker says see if something displaced in the CVT and is killing the engine when you try to throttle up. Pull the cover and watch variator and clutch as you try to throttle.
I know the X500 has a shut off if you tilt it too far. Many bike do that. If it is a fuel shut off find that and check it.
Good luck
Jim
09 Kymco 500Ri (His)
04 Aprilia S500 (Hers)
01 Honda GL1800 (Ours)
DNA Paternity Testing
www.accugendna.com
abobotek
Newbie
Reply #3 on:
April 30, 2009, 09:56:56 AM »
When tipped, fuel can work its way into the emission control system, causing starting problems. Its effect is similar to overfilling the tank. My scoot was shipped with a "do not overfill" warning sticker describing the resultant starting problems.
Red 2007 People S 200
Black 2008 Yamaha Majesty
Back
