Author Topic: fuel problem?  (Read 824 times)
troyhuck
fuel problem?
« on: June 06, 2012, 04:02:07 AM »
Hey guys,
    My scooter is starting real hard and then surges for the first quarter mile or so that I drive it. Thoughts?
Re: fuel problem?
« Reply #1 on: June 06, 2012, 05:42:28 AM »
Bad gas/clogged fuel filter/bad air filter/bad auto choke/loose fitting on the carb/mis adjusted oil pump/ Lots of maybes... You have to try to narrow it down. I would start with new filters/spark plug. Adjust the idle mix screw, and keep checking from there.
troyhuck
Re: fuel problem?
« Reply #2 on: June 07, 2012, 04:53:52 AM »
thanks. I'll start narrowing.
Re: fuel problem?
« Reply #3 on: June 07, 2012, 04:56:33 AM »
More likely than not a clogged filter leading to lean. Maybe a clogged pilot jet.
