Author Topic: Trans oil change  (Read 917 times)
sissy mary
Trans oil change
« on: June 08, 2012, 09:51:10 PM »
Today I changed my trans oil. Everytime in the past when I took out the top fill hole bolt, the trans oil would always seep out of the hole as if it was topped off. This is how I could see how dark the oil was getting. The manual says to put in 0.48 US quart, or just under 1/2 quart. Is this amount right as now it does not seep out? I put in about a half quart exactly, so this should have over filled it by a tiny amount. Is a half a quart ok, or should I top it off? I don't want it to be underfilled, but I don't want to have to much in and build up pressure and blow out a gasket or something. Any thoughts? :-\ :-*
gregspeople250
Re: Trans oil change
« Reply #1 on: June 08, 2012, 11:58:09 PM »
My People 250 slowly leaks gearbox oil out through the output drive seal if it's overfilled.  Messes the wheel with oil, but no damage occurs.
You can use a bent wire or "allen wrench" to check the oil level if you want to run it at or slightly below the check bolt level.  This is what I do now with my scoot' to keep it clean with no issues.
Honda Elite 80 - SOLD
Yamaha Vino 125 - SOLD
Kymco People 250 - SOLD
Kymco Like 200i - SOLD
Vespa 250 GTS - SOLD
Piaggio BV350 - FUN! - SOLD
Buddy 170i - FUN! - SOLD
Honda Silverwing - SOLD
Yamaha TMAX - OUTSTANDING! - SOLD
Honda SH150 - SOLD
Yamaha SMAX - SOLD
Kymco AK550
« Reply #2 on: June 09, 2012, 03:16:51 AM »
There's not much pressure in the tranny as it does in the engine so no need to worry about pressure. Just put the right amount without overfilling.
Hoolander2
« Reply #3 on: June 09, 2012, 03:47:55 AM »
Besides your tranny has a pressure relief hose going into the air box.  I think you should be fine.  Mine never was quite up to the bolt and it was changed at the dealer before I got it.
