...the damage is not extreme...i've seen MUCH worse...you will probably be okay, bro...
..clean away all the shavings!!!
..i always squeeze my clutch, while pushing the belt inward toward its center, FIRST!, before putting clutch on its shaft, thus creating belt slack at the variator's drive center...
..in other words, i install clutch and belt at same time, with variator already in place..
..what happened to you was, you tightened the variator nut to the belt's width...
..always rotate your drive face assembly a cpl-3 times during the tightening of the nut, making sure there is no "wobble"..
..tighten lightly at first, until wobble is gone, then torque it down real good....
