Author Topic: Good day gone wrong...(with pictures!!!)  (Read 6963 times)
Re: Good day gone wrong...(with pictures!!!)
« Reply #15 on: June 14, 2012, 03:36:43 PM »
..i like my Craftsman 19.2v....
« Reply #16 on: June 14, 2012, 04:01:01 PM »
Oh boy... You shoulda waited for the 19.3v... They are soooo much better.
streido
« Reply #17 on: June 14, 2012, 04:29:30 PM »
My 12v is fine when i run it off a car battery charger, cant remember the newtons it makes but its well enough, off my scoot battery it wont work tho.
Its powerfull enough that i stripped my clutch nut not too long ago. Now i give it less "bangs" when i tighten it.  :)
Chaos is my co-pilot.
Kenho21
« Reply #18 on: June 14, 2012, 05:40:24 PM »
Does the 12v run better when you connect or directly to your car battery?
I was gonna do it yesterday but I always feel better about draining the battery through the cigarette lighter rather than directly from the battery for some reason.
streido
« Reply #19 on: June 14, 2012, 05:53:14 PM »
I dont ever use my car battery, i use a charger to power it, something like this one
Just have the wires joined and taped up permanently so i can plug it into the mains and run it off a socket in my garage, works well for me and saves having to get the car out etc.
 The cigarette lighter or battery that you use should use the same power off the battery anyway so if you do it either way it shouldnt make a difference to how much it drains it.
« Reply #20 on: June 15, 2012, 12:15:57 AM »
Running thru the lighter is looking for trouble anyway. There are a but load of TINY wires the lighter is connected thru. It is fairly easy to overheat the circuit before blowing a fuse. Most NEW cars have the lighter circuit run thru the cars computer too. Don't want to over heat that!
« Reply #21 on: June 15, 2012, 01:54:46 AM »
+1 z
Kenho21
« Reply #22 on: June 15, 2012, 01:56:30 AM »
Slapped her back together (correctly) and took her a good 20 miles or so today, running great! Thanks for your guys help with that one, thought I was a goner for a while. Still gonna get some shims though just to be safe.
It still feels like its slipping a little though, but I got 2500km on the stock belt, I think it's just time for a new one. Us it mainly slips with with half throttle or more. All the mods im assuming cause a slightly worn belt to become more apparent.
« Reply #23 on: June 15, 2012, 01:57:12 AM »
..i have a weather-proof 12v "lighter" type auxillary socket wired to nina's battery...charges cell phones, gps etc...
Kenho21
« Reply #24 on: June 15, 2012, 01:58:01 AM »
Yea from now on I'll be attaching its directly to the battery to, good point Zombie.
« Reply #25 on: June 15, 2012, 02:00:16 AM »
..keep in mind, that adding shims will change your variator action...
..aannnd, give your new setup/cleaning some miles to seat in before you jump to changing anything else...
Kenho21
« Reply #26 on: June 15, 2012, 02:04:03 AM »
Right on word, the slipping was happening beforehand too though, so it's makin me think something is goin on down there. 2500km is about the average for a stock belt isn't it?
« Reply #27 on: June 15, 2012, 02:08:26 AM »
..i got 32,000 kms on my original bando belt before it broke..
..actually, that was when i found my way to this forum...
..unless!!..you been modding and straining that bando really hard, it's most like just a baby...
...got some calipers??..measure its width...if it's still @ 17.5-18mm, and doesnt look frayed or cracked and sh**, then it's prolly got quite a bit of use left..
Kenho21
« Reply #28 on: June 15, 2012, 02:13:25 AM »
I'll check it out, could be my jetting too then I guess I'm still getting that right, waiting for some in the mail as we speak.
« Reply #29 on: June 15, 2012, 02:15:51 AM »
..kenho, refresh my memory on your scoot's setup..would y'?
