Author Topic: I need help ASAP! Electrical problems  (Read 3469 times)
Island21
« on: June 17, 2012, 03:55:45 AM »
Hey guys I have an 08 kymco agility 125 and I was riding it and stopped for about 5 minutes and I tried to turn it on but it wont start.
It's weird cause all the lights horn and stuff works
The horn and the starter work when the kill switch is off
It tries to start but nothing
Please help me it might not have been to clear what I said cause its hard to explain ask some questions please need help ASAP thanks!!
Oh and the spark plug does not spark and I got a new spark plug
Re: I need help ASAP! Electrical problems
« Reply #1 on: June 17, 2012, 04:00:00 AM »
Try screwing the plug boot off, and cutting back about 1/2" of wire. Screw it back on, and see if it works.
Island21
« Reply #2 on: June 17, 2012, 04:02:39 AM »
What is a plug boot
I'm 15 sorry
Island21
« Reply #3 on: June 17, 2012, 04:04:39 AM »
Also the manual says it could be the Cdi?!?
« Reply #4 on: June 17, 2012, 04:05:05 AM »
15! Your up a little late!   Sorry Bro! The rubber cap that goes on the spark plug. It will unscrew from the wire. The wire may have burned up inside.
« Reply #5 on: June 17, 2012, 04:06:11 AM »
Don't worry about the cdi yet. They very rarely go bad on a 125.
Island21
« Reply #6 on: June 17, 2012, 04:10:31 AM »
I know I've been trying to fix this dang thing
Okay so I cut it and nothing not even kick starter
Island21
« Reply #7 on: June 17, 2012, 04:14:15 AM »
Cut it didn't work so I took the spark plug out and still non spark
« Reply #8 on: June 17, 2012, 04:14:39 AM »
Find the wire harness from the engine to the bike. Pull it apart, and check the connectors inside. Check the ground wire from the engine to the frame. It should not move at all. Check the ground wire from the frame to the battery. It should not move either. For any more than that you will need a Multi Meter to test the different components.
« Reply #9 on: June 17, 2012, 04:16:06 AM »
Before pulling out your hair... Put the spark plug wire near metal, and see if a spark jumps. You might just have a dead plug.
Island21
« Reply #10 on: June 17, 2012, 04:17:54 AM »
I put the wire on metal and nothing
Island21
« Reply #11 on: June 17, 2012, 04:20:50 AM »
See the thing is I just went to my local dealer (an hour and a half away) an got new spark plug
« Reply #12 on: June 17, 2012, 04:24:13 AM »
My GUESS is something got tugged loose, or a bad connection fell apart. Try removing the wire that goes to the kill switch. The switch may have gone bad
Island21
« Reply #13 on: June 17, 2012, 04:36:27 AM »
There are two wires for the kill switch I've tried touching them together and trying to start it but it didn't work
« Reply #14 on: June 17, 2012, 06:55:29 AM »
They HAVE to be separated... Try that
