Author Topic: clock  (Read 2370 times)
fshfindr
clock
« on: June 17, 2012, 06:54:15 PM »
The clock on my Yager has stopped keeping good time.  It is so far off, I don't know if it is fast or slow.  Anybody else have a similar problem?
Richard L.
6.18.12
UPDATE;  This AM the bike would not start.  A quick investigation found that the pos. terminal on my battery was very loose.  I think that that was also the clock problem.
Richard L.
« Last Edit: June 18, 2012, 11:20:53 PM by fshfindr »
Richard L. in Bellmawr
DaveABQ
Re: clock
« Reply #1 on: June 18, 2012, 07:24:02 AM »
mine seems to be keeping pretty good time, how much does yours lose over how long?
Ronnath
Re: clock
« Reply #2 on: June 18, 2012, 11:04:23 AM »
mine keeps pretty good time - exactly one-half hour off since my addled mind couldn't figure how to set the minutes when i first programmed it. duh.
is your bike still under warranty?
CapnJ
Re: clock
« Reply #3 on: June 18, 2012, 02:28:58 PM »
Mine has been keeping excellent time. Maybe a minute off since DST change.
2 wheels is 2 wheels, But China Ain't Taiwan.
Re: clock
« Reply #4 on: June 18, 2012, 04:47:56 PM »
Mine drifts about a minute a month.....
ScooterWolf
Re: clock
« Reply #5 on: June 18, 2012, 08:41:22 PM »
Mine seems to be doing good too. Are the clocks run on a separate battery? If not is the onboard computer calculating time between starts and stops?
-Wolf
Re: clock
« Reply #6 on: June 19, 2012, 09:24:10 PM »
I missed the part about the loose battery connection. I had a tach that went nuts up and down with no change in engine speed and it was a loose battery connection CAUSED BY THE BATTERY CLAMP PANEL NOT BEING INSTALLED BY THE SANCTIFIED DEALER. Then it took four months for the morons to get me the part and even had to get Kymco USA involved to pry them off dead center. I'll bet your clock will work fine since you have cinched up the terminal. Let us know.....
fshfindr
Re: clock
« Reply #7 on: July 05, 2012, 06:34:48 PM »
Yep, it was the loose connection.  Had to be my fault.  :-[ :-[ :)
Richard L.
