Author Topic: Oil leak - failed cylinder gasket.  (Read 2070 times)
abobotek
« on: June 19, 2012, 06:46:56 PM »
At around 4700 miles, I started noticing a small (1-2 drops/mile) oil leak.  I took the bike apart and found the cylinder gasket (between the cylinder and crankcase) pinched out of the joint.
I have found a few other references to this happening on Kymcos, but it doesn't seem to be a common problem.
Question:  How should I fix this?  Possibilities:
* Loosen the cylinder and squirt in some 'form a gasket' liquid
* Pull the cylinder with the engine in the bike
* Remove the engine and replace the gasket on a bench
Also, should I pull the piston from the cylinder, or just try to loosen the cylinder and remove the wrist pin with the piston still in the cylinder?
Regards,
Alex
« Last Edit: June 19, 2012, 06:49:18 PM by abobotek »
Red 2007 People S 200
Black 2008 Yamaha Majesty
Re: Oil leak - failed cylinder gasket.
« Reply #1 on: June 20, 2012, 12:25:24 AM »
The easiest way in my opinion is to pull the engine. You can clean it all up, and work like a gentleman. You are always better off leaving the piston inside the jug, and removing the wrist pin unless you plan to change the rings.
I use Permatex #2, omc perfect seal, or Indianhead shellac. Use it to "glue" ONE side of the gasket in place. One side only. Never use that silicone RTV crap. It's garbage.
« Reply #2 on: June 20, 2012, 12:27:05 AM »
ps... Get a new exhaust gasket, and the "O" rings for the carb/intake. Head gasket/base gasket/valve cover gasket
abobotek
« Reply #3 on: July 15, 2012, 07:34:10 AM »
My S 200 is back on the road again, leak-free thanks to a new cylinder gasket and a few other new gaskets.
One thing I should mention is that the oil strainer was full of pieces of the old failed gasket.
« Last Edit: July 16, 2012, 05:40:38 AM by abobotek »
« Reply #4 on: July 15, 2012, 09:08:17 AM »
Nice... ;D
