Author Topic: Side stand spring routing  (Read 3386 times)
The Rookie
« on: June 20, 2012, 08:07:15 AM »
Hi all, the daughters bike came with the side stand removed (go faster mod...????) I now have one but for the life of me can't find a way to route the spring so it works, it either pulls the stand down ALL the time or up ALL the time, can anyone post some photo's (PLEASE..........) so I can fit this damn thing as the bikes too heavy for her (8stone/112lbs/50Kg) to put on the centrestand on anything but smooth flat ground.
Thanks in advance!
Re: Side stand spring routing
« Reply #1 on: June 20, 2012, 08:25:13 AM »
Do you have all the parts?
The Rookie
« Reply #2 on: June 20, 2012, 08:47:27 AM »
Yes, have stand, special bolt, spring and plate, plate orientated as that parts pic.
« Reply #3 on: June 20, 2012, 09:07:12 AM »
All you need to do is to hook the spring to the stand and the plate, right?
The Rookie
« Reply #4 on: June 20, 2012, 09:29:44 AM »
wrong....which side of the pin on the end of that bolt does it route for example.......I've had it connected 3 ways and none worked.....photo would be great (top end)......
« Reply #5 on: June 20, 2012, 09:55:13 AM »
Isn't the Agility side stand self-retracting? Meaning, its up all the time? It retracts when lifted from the ground.
streido
« Reply #6 on: June 20, 2012, 10:02:20 AM »
Im at work but if nobody else posts pics then i'll take some once i get home and post them up. Have you got the workshop manual? Links are on here somewhere.
Chaos is my co-pilot.
The Rookie
« Reply #7 on: June 20, 2012, 11:16:45 AM »
Vivo, if its self retracing then I got it right once, I assumed it would be an over centre spring so the spring held it down and up depending where you pushed it to, that is what I'm used to on bigger bikes.
Streido, no, didn't know it was on here, will go look, photo's would be great, also whether the spring loops round the stand from in front or behind!
streido
« Reply #8 on: June 20, 2012, 12:42:49 PM »
Finish at 4:00, heres a link i think for the manual meantime http://www.eserviceinfo.com/downloadsm/35810/Kymco_Agility%2050.html
Its Wordslingers link so blame him if its wrong  ;D
streido
« Reply #9 on: June 20, 2012, 04:12:05 PM »
Its meant to always pull the stand up when the bikes weight is off it. You prob had it on correct earlier. You hold it down with your foot then lean the bike on it to keep it down, soon as you prop the bike up straight it should pop up.
Man i really need to jetwash under there  ::)
The Rookie
« Reply #10 on: June 20, 2012, 05:30:07 PM »
Steve,
OK thanks for that, yes had it on right once (BUGGER!)
Simon
streido
« Reply #11 on: June 20, 2012, 06:18:13 PM »
When u do get it on and shes using it tell her to give it a little kick forwards once its sitting on it, hold the bars tho too, thats what i do.
I only use the side stand for short stops or to pose if i park next to some bikes, theyre not too steady i feel and a knock on the scoot by a passer by would knock it over im sure. Centre stand is much safer. You cant rev it up on the side stand either or it goes flying forwards.
Theres a knack to the main stand so its easy, you just need to get used to it, took my wife 2-3wks but now she finds it easy when before she couldnt do it at all.
The Rookie
« Reply #12 on: June 20, 2012, 08:33:06 PM »
Steve,
got it fitted again, what knack do you have?
streido
« Reply #13 on: June 20, 2012, 09:01:21 PM »
Left hand on l/h grip, right hand on l/h side of luggage bar, right foot on main stand, stand one footed on main stand and slightly pull back with hands if needed. Just practice, its simple, your weight lift ot on the stand, even do it one handed now  :D
« Reply #14 on: June 21, 2012, 01:16:18 AM »
Maybe the side stand was removed by the previous owner for safety purposes.
By the way Rookie, because of your question, Streido now has to clean his scoot... ;D
