Author Topic: Malossi Multivar  (Read 3100 times)
Cortez
    • My flickr account
Malossi Multivar
« on: June 20, 2012, 01:32:46 PM »
Anyone here using the Malossi Multivar?
Did you use the supplied yellow spring or stock?
Any experiences (people who actually own a DT300 or People300 and have the multivar, please)?
Let's hear it!
'08 FZ6n S2 ABS
subwoffer
Re: Malossi Multivar
« Reply #1 on: June 22, 2012, 12:36:24 PM »
just bought one and sold after 2 weeks . feels like its killing the engine . the rpm goes to 8.000 but the acceleration is not as you think it would be . just a bit more of a power , that not worth the high rpm .
sometimes felt stupid , because the engine is screaming and the acceleration is  really a  bit more then the original .
i used the white clutch spring , that what came with the kit . btw i left the white spring after installing back my original VAR .
subwoffer
« Reply #2 on: June 22, 2012, 12:43:42 PM »
P.S
i would like to hear from owners that only changed  the weights in the original variator , to know how the engine behave .
Cortez
    • My flickr account
« Reply #3 on: June 22, 2012, 01:26:18 PM »
You could have changed the weights in the multivar too.
The most popular choice is 22-24gr or 20-22gr dr pulley sliders.
You'd still have 8000 with 20gr sliders at full throttle, but not that high revs on higher
cruising speeds.
I put 14gr sliders in original CVT and got about 6500 revs at full throttle accelerations
and 500 revs less at any speed above 60mph compared to the stock 15.5gr setup.
75mph is at 6500 for example, and stock bike will do 7000 at 75mph, but more
importantly, now I have power to overtake at 50-55mph which I didn't have before
because the bike was stuck at 5500 revs.
Finely tuned multivar should be able to do this even better.
I've already got the suggestion to keep the stock spring (I got the yellow malossi spring),
and I know I won't like the 20gr weights that it comes with. I'll try it for a while and then
decide which slider weight to get.
I'd want at least 7000 revs at WOT.
'08 FZ6n S2 ABS
subwoffer
« Reply #4 on: June 24, 2012, 09:58:06 PM »
15 gr isnt that on 125\200 cC?
Cortez
    • My flickr account
« Reply #5 on: June 24, 2012, 09:59:43 PM »
It can be.
I've had 14gr on 125cc, and now 15.5 on 300cc.
There's really no rule.
Some CVTs use 8 weights and they're obviously lighter then.
'08 FZ6n S2 ABS
