Author Topic: from stock 17mm Carb to 19mm carb  (Read 1185 times)
scooterman11
« on: June 22, 2012, 07:17:25 PM »
Hey guys so i got a 19mm gy6 qmb139 carb for my 08 agility 50 removed the stock 17mm
and wasnt sure if the new carb needed to be tuned and also i feel like my automatic choke is not working is there a fuse because the choke unit is brand new along with the carb please let me know asap its really bothering me and i want to get it figured out
thanks Mitch
Peters
  • In Glock I Trust
Re: from stock 17mm Carb to 19mm carb
« Reply #1 on: June 22, 2012, 07:48:38 PM »
Did you change the main jet? The stock jet for a 150cc will be way too big for a 50cc.
Why do you think the choke isn't working. Will it start or not?
*2001 ZX-50 beater
Peters
  • In Glock I Trust
« Reply #2 on: June 22, 2012, 07:52:52 PM »
What kind of mods do you have?
*2001 ZX-50 beater
scooterman11
« Reply #3 on: June 22, 2012, 07:55:00 PM »
I just got the carb today and the 19mm is made for  my scooter
The reason i dont think the choke is working is because usually when i start it,the choke helps it, it wants to idle when i finally get it running i hope i just need to tune the screw on the side of the carb, and would it be possible that i need to put on my after market leo vince pipe
scooterman11
« Reply #4 on: June 22, 2012, 07:55:55 PM »
the only mods I have are A leo vince pipe and the new 19mm carb which i just got today
streido
« Reply #5 on: June 22, 2012, 08:26:07 PM »
I would still check what size the main jet is, unless it said on the box?
The leo vince shouldnt matter, take it you have some exhaust on now tho?
Chaos is my co-pilot.
scooterman11
« Reply #6 on: June 22, 2012, 09:46:13 PM »
It will start up using 1/2 throttle and run it just wont idle even after it is warmed up. I've also checked valve adjustment, and compression but with no luck . it just won't start on it's own.
« Reply #7 on: June 22, 2012, 11:14:40 PM »
if you can find a squeeze ball to put on the gas line that well work great. I have one on mine and all I have to do is give it a few pumps and the scoot starts right up. that way you dont need the choke.
scooterman11
« Reply #8 on: June 23, 2012, 12:41:10 AM »
That's a great idea,  but the other issue is keeping it running when I let off the throttle
« Reply #9 on: June 23, 2012, 03:29:00 AM »
You Have to adjust the mix screw on every engine.
