Author Topic: Checking the valve clearance  (Read 1142 times)
08087
  • 09' Peoples 200, NJ
« on: June 23, 2012, 07:12:21 PM »
I'm not very handy, but I was going over my owners manual the other night and it says to check the valve cleanses every so often. How does one go about doing this?
Re: Checking the valve clearance
« Reply #1 on: June 23, 2012, 07:17:07 PM »
any thing you need to know about how to do something can be found on youtube comes in handy.
whiteknight
  • ..Knight Tweed..
« Reply #2 on: June 23, 2012, 07:21:29 PM »
or even better search on here for it. but then if it aint here do what blue said and do a youtube search.
« Reply #3 on: June 23, 2012, 08:44:39 PM »
There is a post on here somewhere that said take out the seat tub and remove the "tupperware" plastic forward of the tub to gain access. That gives you plenty of working room. Feeler gages and metric wrenches is about it. You may want to pull the spark plug to make it easier to turn the engine to get the cams to the base circle to check/adjust. Get one of the wrench-heads to show you if you never have done this before OR as someone already said, YOUTUBE!
08087
« Reply #4 on: June 23, 2012, 08:55:03 PM »
When I get some time I'll give youtube a shot. I don't have the tool you mentioned so I may just have to have someone do it for me.
