Author Topic: flat spot  (Read 882 times)
superscoot
  • if you see blue light's ""RUN""
flat spot
« on: June 23, 2012, 11:47:52 PM »
dunno if im correct but i may have a flat spot on take off as soon as i open the throttle up she creeps forward then takes off like a rocket any idears?
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 5.7 gram rollers
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
naraku 1500 contra spring
naraku 2000 clutch springs
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
streido
Re: flat spot
« Reply #1 on: June 24, 2012, 12:58:14 AM »
Sound like a cvt issue. Check the rollers are not worn, the belt is within its tollerance width, the clutch pads condition - they may just need sanding with some paper if theyre glazed or dirty, also lightly sand inside the clutch bell where the pads rub, check clutch fly springs are ok and give it general clean out with a dry paintbrush or some cleaner spray.
If that doesnt work then check the throttle cable moves with the grip by looking at it at the carb as your twist the throttle on the stand. Could be its worn or sticking.
Chaos is my co-pilot.
superscoot
Re: flat spot
« Reply #2 on: June 24, 2012, 01:13:10 AM »
thanks for the reply i do have a new belt ive yet to put it in ( got to get a inpact wrench ) so i have a look as soon as i can thanks
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
streido
Re: flat spot
« Reply #3 on: June 24, 2012, 01:33:54 AM »
You can always open up the cover and give it a clean out,  either with a spray cleaner or even just a paintbrush and without dismantling the whole thing, might help short term till you can get an impact wrench, if it is just dust and dirt.
superscoot
Re: flat spot
« Reply #4 on: June 24, 2012, 11:31:43 AM »
i got the cvt cover off yeah its abit dirty/dusty the belt has also seen better days....just aswell i have a replacement should be getting that inpact wrench within then next couple of days....( works fault ) did get paid :( the rollers are also fine got a little trick to get the variator off with the use of a small spanner :) but the clutch is a whole diffrent story lol.....ill also give the cvt a good going over when it stops raining... thanks again for your help :)
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
streido
Re: flat spot
« Reply #5 on: June 24, 2012, 12:56:22 PM »
No probs, just hope it works  :)
