Author Topic: Agility 125 Performance @ High Elevation  (Read 1690 times)
AgilityOnAnRV
« on: June 24, 2012, 06:51:48 PM »
I've been riding my Agility 125 in Austin, TX which is pretty close to sea level (~500' elevation).
This summer we'll be traveling around the country and plan to bring the scooter along. How should I expect performance to change at much higher elevations, say 5000' and 7000'?
Are there any modifications that I need to do or should do to prepare for the change?
jprestonian
    • a scooter called wanda
Re: Agility 125 Performance @ High Elevation
« Reply #1 on: June 24, 2012, 07:22:41 PM »
This will give you some good data.
tortoise
« Reply #2 on: June 25, 2012, 05:33:49 PM »
"Although a CV-equipped bike doesn't go rich at altitude the way a fixed jet carb does, it will lose power due to the lower air pressure, which is reduced about 10% for every 3,000' gain in elevation.   With 10% fewer oxygen molecules going into the engine on each intake stroke, we should reduce the fuel by 10% to get back to that "ideal" fuel-to-air ratio of 12.5 to 1 for maximum power." . . attribution
For the benefit of others, please update this thread with your findings.
AgilityOnAnRV
« Reply #3 on: June 26, 2012, 05:54:29 AM »
I definitely will, although it'll be at least a couple of weeks before I'm testing this.
