..tried the HOCA bearing spring base...
..knew there was a problem while installing, because i couldnt fully compress the torque spring by hand...
..it won't work until i take @ 1/4" off the top spring support...
..this piece bottoms out on the bearing base, which results in belt slippage, lower top speed and way high rpms over 45 mph, with no further increase in speed...
