Author Topic: opinions on the stage 6 clutch  (Read 5466 times)
whiteknight
  • ..Knight Tweed..
Re: opinions on the stage 6 clutch
« Reply #15 on: June 30, 2012, 11:40:31 PM »
  I'd get the stage 6. It's just easier to tune than the Malossi
hmmmm i have a Malossi clutch and a Stage 6 bell.....im gonna have fun wooop!! ;D
« Reply #16 on: July 01, 2012, 12:00:34 AM »
..my stage6 and delta will not work together!..on my s9...
« Reply #17 on: July 01, 2012, 12:54:21 AM »
Oooooops...
« Reply #18 on: July 01, 2012, 01:33:10 AM »
..well, i can squeeze the oem driven and moving pulley, with the delta clutch.. all the way until it hits that stage6 bell...
..that should not happen...
« Reply #19 on: July 01, 2012, 05:54:46 AM »
With mine the pulley hits the clutch about 3mm before true full open. I'm gonna use the Malossi in the GY6
« Reply #20 on: July 01, 2012, 11:34:07 AM »
..mine too..
..debating on taking about 4mm off the bell....
« Reply #21 on: July 01, 2012, 12:42:25 PM »
..mine too..
you can do that . what does that do for the scoot.
« Reply #22 on: July 01, 2012, 02:01:13 PM »
It would allow me to use the bell with any clutch/torque driver setup...
« Reply #23 on: July 04, 2012, 05:56:11 AM »
No... My pulley hits the actual clutch. Not the bell. Yours can be shaved to fit. Mine has to be shimmed. Malossi doesn't really trial fit everything I think...
« Reply #24 on: July 05, 2012, 12:13:46 AM »
..true..my naraku td with the malossi hits the clutch...
« Reply #25 on: July 05, 2012, 09:42:44 AM »
Yeah. Thats what I mean.
Kenho21
« Reply #26 on: July 10, 2012, 04:38:29 PM »
I'm waiting on a few transmission parts this week (Multivar, 1500 contra, variator fan, then sliders once I figure out what weight I want) and I'm thinking about getting the Stage 6 MKII clutch after I get this parts run in. If I get the Stage 6 will I also have to get a new clutch bell to make it worth it?
« Reply #27 on: July 10, 2012, 04:45:31 PM »
..the stage 6 is a awesome clutch, and will work well with the oem bell...
Kenho21
« Reply #28 on: July 10, 2012, 08:48:03 PM »
So to clarify, is the different between a $100 clutch bell and a $50 clutch bell worth the extra dollars? I assume it's just a quality difference and not size or anything...
« Reply #29 on: July 10, 2012, 10:34:55 PM »
It's all about the HYPE! The NEW Malossi is a safety bell that will capture shrapnel if the clutch explodes. That is the best bell you can buy. Bells like the Nakaru are built with the same steel/methods as the OEM. Some have a second "skin" applied on top for looks. The Stage 6 MKII is an actual milled piece vs stamped steel. I haven't run it yet but it appears much stronger than OEM/Malossi Delta. Unless you have a specific design, or use for the scoot any of the top brand bells are fine. Just stay away from ebay/cheap/China replacements. These are common stamped steel, and have very little strength. The welds are "spot welds". One weld cracks, and the bell goes where it wants.
Just to top it all off... I prefer the bells with fans built in, and the lighter the better.
