Author Topic: Portable air compressor  (Read 1989 times)
08087
  • 09' Peoples 200, NJ
« on: June 27, 2012, 10:03:42 PM »
Looking for a good reliable portable air compressor I can carry arouond with me for my scoot. I have to look yet but I think I have a 12v outlet under my seat in which I can run it with, if not I guess a couple of alligator clips will work off the batt.
The smaller the better of course.
Pimpy1
  • Mo Hoes Power
Re: Portable air compressor
« Reply #1 on: June 28, 2012, 12:03:23 AM »
2011 Kymco Super 8 2t
2006 Kymco People 250
08087
« Reply #2 on: June 28, 2012, 01:34:05 AM »
I have one of these. Cheap, Small and comes with a load of cable hook-ups. http://www.amazon.com/gp/product/B001UQRUU6/ref=as_li_ss_tl?ie=UTF8&tag=kinderinfocom-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001UQRUU6
Great! Just the right size too. Have you used this yourself?
« Reply #3 on: June 28, 2012, 02:00:54 AM »
..i bought me a 12vdc weatherproof socket, and wired it directly to the batt terminals on my s9..
..charges cell phones, gps etc nicely...
« Reply #4 on: June 28, 2012, 02:10:03 AM »
I have that also but currently using a mini bicycle pump. Saves more space and doesn't require any battery.
Pimpy1
  • Mo Hoes Power
« Reply #5 on: June 28, 2012, 03:45:24 AM »
Yes i have the very one. I like it because it will plug directly into my Battery Tender charger the I have already hardwired to my scoot.
http://www.amazon.com/gp/product/B000CITK8S/ref=as_li_ss_tl?ie=UTF8&tag=kinderinfocom-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B000CITK8S
I just leave this part on my battery and I can plug in the charger or the compressor to it in a second.
Dolemite
« Reply #6 on: June 28, 2012, 07:18:49 PM »
Be careful with using a 12v accessory powered pump. I blew the accessory port fuse in my Like 200i last week using one. I replaced it with a 5amp blade fuse (instead of the glass cylinder, i couldn't find one that matched in the local auto shops) I thought about replacing the 5amp with a 7amp fuse when replacing it.  Any thoughts on if that's a good/bad idea???
08087
« Reply #7 on: June 28, 2012, 07:43:58 PM »
Bad idea!
You never replace a 5 amp with a greater value fuse or 20 amp with a greater value fuse for that matter. You want the fuse to blow that protects you from doing damage or starting a fire on ur scoot. Call a local scoot place and order some fuses, get spares if you think you'll need them. If you keep blowing fuses you may have a bigger problem or your just drawing too much power from the outlet.
« Reply #8 on: June 29, 2012, 01:43:37 AM »
Bad.  Don't use an accessory port for a compressor. It's only for cell phones, and other low powered gadgets. Use alligator clips and connect directly to the battery.
perronotto
« Reply #9 on: July 03, 2013, 09:24:19 AM »
mrmike
  • Syuracuse, NY
« Reply #10 on: July 03, 2013, 01:27:33 PM »
  I installed a second accessory plug on my GTI300. The factory plug has a very low fuse and is only for certain things. I use my new plug for my GPS and battery tender.
