Author Topic: Friend of mine wanted me to ask  (Read 1204 times)
Syl
« on: June 28, 2012, 08:25:55 PM »
A 200 Yager GT starts fine idles fine but when throttled up it bogs down or describing it as missing real bad. Getting it throttled to a higher rpm, it appears to run a bit smoother but.........?? Appreciate any input, I am normally on the Xciting 500 Forum...name is Syl... Thank You
Re: Friend of mine wanted me to ask
« Reply #1 on: June 28, 2012, 08:51:40 PM »
Syl, what year, how many miles, how long has this been happening, what kind of gas and/or additives have been used, where parked (outside, inside, general conditiions), is this the original owner and I'll bet among all of us will be able to bullseye this problem.
Syl
« Reply #2 on: June 28, 2012, 11:55:31 PM »
Thanks CROSSBOLT, passing these questions on to be answered and I will get back...till than thank you for the response
ScooterWolf
« Reply #3 on: June 29, 2012, 02:31:58 AM »
Sounds like it could be one the classic roller weight problems. If the miles are close to 10 thousand it may also be a fuel filter problem as well.
-Wolf
Syl
« Reply #4 on: June 29, 2012, 04:49:34 PM »
Problem solved after many checks.....The Coil was bad even though it check good but was replaced just to be safe and behold..."Problem Solved". Again, thanks for the interest and help.
