Author Topic: elec. choke  (Read 2757 times)
elec. choke
« on: June 28, 2012, 08:56:20 PM »
Has anyone ever have a problem with the bottom part of the seat hiting the elec. choke.
whiteknight
  • ..Knight Tweed..
Re: elec. choke
« Reply #1 on: June 28, 2012, 09:24:11 PM »
cant say i've had a problem..is your seat sitting properly on the plastic around the bottom or your carb might be sitting quite high...show some pics of it if you can blue, might get a better idea of whats going on.
streido
Re: elec. choke
« Reply #2 on: June 28, 2012, 09:25:32 PM »
Nope. Never. Least not yet. Didnt you fit a replacement carb before? Maybe its a little bigger choke on that?
Chaos is my co-pilot.
whiteknight
  • ..Knight Tweed..
Re: elec. choke
« Reply #3 on: June 28, 2012, 09:28:23 PM »
when i fitted my 19mm race carb i still had clearance and the choke was a little bit bigger than stock.
Re: elec. choke
« Reply #4 on: June 29, 2012, 02:34:19 AM »
yes I did put a dif carb in so far things are ok I put a few washer onder me seat bolds to raise up.
whiteknight
  • ..Knight Tweed..
Re: elec. choke
« Reply #5 on: June 29, 2012, 10:57:40 AM »
yea but i can only see that being a "fix for now"  how big is the carb you put on? i have a 19mm race carb and my mate has put a 24mm carb on his Ag (bbk'd to 80cc) i think he modified under the seat to fit it.
mono
Re: elec. choke
« Reply #6 on: June 29, 2012, 03:36:37 PM »
On both my Agilities the choke (OEM carb) is pressing the rubber hood thats on the carb against the inside of the seat.
There seems to be no real problem in my case(s), except for some wear marks, but it fits quite tightly and I can easily imagine that in some cases it can be a real problem...
With the 2006 A50 I've removed the small plastic cover of the choke (it comes off by sliding it upwards) and replaced it by a piece of heatshrink tube to give it more room while still protecting the cable entry (which is the most important function of this cover as far as I can tell)
Re: elec. choke
« Reply #7 on: June 29, 2012, 11:59:34 PM »
Ya I took my hood off to I had to raise the seat so high the lock on it wont work. maybe if I just rase the frone of the seat.
streido
Re: elec. choke
« Reply #8 on: June 30, 2012, 12:39:35 AM »
Or as a last resort you could maybe cut out a small hole where the choke hits and let it sit inside the luggage box, then your seat can sit back down where it should be and bolt in and the key will work again?
Re: elec. choke
« Reply #9 on: June 30, 2012, 01:22:00 AM »
ya thats my next step.
whiteknight
  • ..Knight Tweed..
Re: elec. choke
« Reply #10 on: June 30, 2012, 12:16:26 PM »
i have a feeling i made need to modify my seat to accomadate my polini filter.
Re: elec. choke
« Reply #11 on: June 30, 2012, 12:29:56 PM »
I might just cut out the whole bottom and replace with a peace of wood. and then I can go with a 20 mm carb........
whiteknight
  • ..Knight Tweed..
Re: elec. choke
« Reply #12 on: June 30, 2012, 12:38:51 PM »
your not thinking of replacing the bottom of the seat well with wood?! wood and excessive heat dont mix too well.
mono
Re: elec. choke
« Reply #13 on: June 30, 2012, 01:20:19 PM »
Just to make sure : I guess you did know that the choke can be pointed in any direction that you please ?
Just a thought... I replaced the OEM carb with a brand new one on my 2010 Agility today, and I had to turn the choke 90 degrees to make it fit under the seat, just like I had to do with the new one on my other Agility... Those carbs all seem to be factory-assembled with the choke pointing sideways, which doesn't fit under the seat...
« Last Edit: June 30, 2012, 01:21:57 PM by mono »
Re: elec. choke
« Reply #14 on: July 01, 2012, 12:40:59 AM »
mmmm thanks mono Ill have to try that.
