Author Topic: Agility 50  (Read 1182 times)
scooterman11
« on: June 29, 2012, 10:11:58 PM »
 I spent all day at my dealer with the service guy trying  to figure out just what is going on
i put all the stock jets back in my stock carb and she still does want to idle still seems like shes getting to much gas
could it be a timing issue, crank seal issue, i am just mind boggled as to was it could be
we even put a brand new plug in it with a emgo cone airfilter thinking it might just need more air
I need Help its really starting to bum me out that i can't get it running the way it use to
there more help the better
Re: Agility 50
« Reply #1 on: June 29, 2012, 11:57:25 PM »
try a new carb all around.
streido
Re: Agility 50
« Reply #2 on: June 30, 2012, 12:36:39 AM »
Sounds like maybe a manifold leak?
Chaos is my co-pilot.
mono
Re: Agility 50
« Reply #3 on: July 01, 2012, 02:19:14 PM »
You say it used to run fine...
Did you change anything just before it went wrong, or can you describe when and how exactly the problem started ?
