Hi!
Your options are good, I've checked them already.
The side stand is OK
Kill switch and brake switch OK
Spark out OK (NGK CR8EIX, NGK CR8E), I dont know, how to check it when its in
AC OK, it pumps (as you said click click) gas (maybe too much
I hope the compression is good, when the sp plug is out it pumped the mixture very fast and hard next to my finger, but mechanic should check it
At the end, the electricity. This is the worst, it can be a small problem, but to find it can be a nightmare. The COIL?? Good idea, gonna tell mech, but change it will be hard in my country. Which Kymco has the same coil?
