Author Topic: 2008 Agility 50 rattling at speed  (Read 8425 times)
Re: 2008 Agility 50 rattling at speed
« Reply #30 on: July 07, 2012, 07:02:43 AM »
  There are LOADS of vids... I would pull the cover. You may be loosing your belt. The buzz may be a spinning thread from the belt? Or a loose variator. The fan will hit, and buzz
« Reply #31 on: July 07, 2012, 12:25:28 PM »
i like that noise....sounds cool and people turn to see what the hell is making the strange noise then see an Agility....confused faces all around and a big smile on my face.
the good old days when makeing noise on your bike was cool. like sticking a playing card in your spokes just to here it hit on the fram every time it went around.
whiteknight
  • ..Knight Tweed..
« Reply #32 on: July 07, 2012, 06:33:17 PM »
yea except i dont know how it makes the noise. anyway its making a new mean noise...let off the throttle and it burbles.
KTIzkhanilov
« Reply #33 on: July 07, 2012, 11:09:45 PM »
Thanks so much!  this video clarifies alot.  I'm more confident about opening up my scooter's drive system now that I see how simple it is.
I went out and got a recording of the sound I'm referring to, seeing as it's kind of difficult to explain..
Listen to this:
http://www.mediafire.com/?dgpg51zfskdidp2 (Recorded with cellphone, quality might be lacking)
The sound that I've been trying to describe can be heard at around 5 seconds
Don't quote me on this, but it APPEARS to be coming from the components featured in the video I quoted.
Thoughts?
« Last Edit: July 08, 2012, 01:06:03 AM by KTIzkhanilov »
« Reply #34 on: July 08, 2012, 12:30:31 AM »
Get a "page not found"
« Reply #35 on: July 08, 2012, 12:47:43 AM »
I beleave it to be a easy fix for ya if you never took your drive train apart befor its most likely it just needs a good cleaning. belt dust and dirt build up well make everything sound bad. I did mine and it wroked wonders for me . also your gears might be hiting your starter bendix.make sure you clean every little hole in and out around the drive tarin. also the kick start cover well need cleaned good. keep it dry dont put greese on it. you can use wd40 to clean it but make sure you dry it off good.theres a little hole that the starter bendix hits in to when you kick it over clean it out good.and take the gears out of the cover and clean the holes you well see there also.
KTIzkhanilov
« Reply #36 on: July 08, 2012, 01:05:27 AM »
BUMP:  Link fixed.
« Reply #37 on: July 08, 2012, 01:09:24 AM »
I think your Var is loose. Ps... It's not a F'ing moped  ;D
« Reply #38 on: July 08, 2012, 02:46:18 AM »
ya x2 that or its what I posted earlyer.while you are in there check your rollers.
« Last Edit: July 08, 2012, 02:47:55 AM by blue »
« Reply #39 on: July 08, 2012, 05:22:16 AM »
..well, that sounds like sh**!..lol..
KTIzkhanilov
« Reply #40 on: July 08, 2012, 07:12:56 AM »
Yes.  But what kind of sh** specifically?  ;)
streido
« Reply #41 on: July 08, 2012, 01:11:59 PM »
Serious sh**  :D
I would def open it up and check all cvt components and belt condition, until you do that then it could be anything. Dont know if its just wind being picked up but that sounds terrible.
Chaos is my co-pilot.
« Reply #42 on: July 08, 2012, 04:10:34 PM »
open that sh** up then take a pic let us see......................
« Reply #43 on: July 09, 2012, 12:17:36 AM »
...yes!!  open it up!!!
..you gotta open it!!!
..a pic is worth a thousand audio clips....
« Reply #44 on: July 09, 2012, 01:31:55 AM »
Go into the light!!!    no wait... yeah go on... maybe IDK!
