Author Topic: Front use only?  (Read 1893 times)
Glenn
Front use only?
« on: July 04, 2012, 01:20:56 PM »
I have a super 8 50 2t and had a flat on the rear tire. Could'nt repair it so went to dealer purchased the standerd size tire for the rear. When I was putting it on I noticed it said "front use only". Does it matter?
Re: Front use only?
« Reply #1 on: July 05, 2012, 02:22:53 AM »
The tires have same size (front and rear) Check other specs of the tire other than size. The rear might have a different load index (load rating) than the front. My opinion...
Peters
  • In Glock I Trust
Re: Front use only?
« Reply #2 on: July 05, 2012, 02:25:55 AM »
Tread patterns can be different
*2001 ZX-50 beater
Glenn
Re: Front use only?
« Reply #3 on: July 05, 2012, 07:48:44 PM »
Thanks for the response. I checked the load ratings,The front is 480lbs the new rear is 520lbs.The tred pattern does look like it will be fine. The pattern goes a bit higher on the side walls than a standard rear tire pattern. I'm going to run it like it is. I will report back from home or the hospital if I have any problems ;D. Just a heads up...My front tire size is a 120/70-14 not the 100/80-14 that my manual says it has.I did by it new(Helped the dealer uncrate it).Thanks again.
Re: Front use only?
« Reply #4 on: July 06, 2012, 12:06:22 AM »
Front tires are made with a round profile that gets lower in turns. The rear is made to lift the scoot taller into a turn. It will feel strange using a front on the rear. You will lose grip easier. I would try another route...
Glenn
Re: Front use only?
« Reply #5 on: July 10, 2012, 09:14:42 PM »
Update...Called Dunlop rep, He said front tire on back is a big no-no. It changes brakeing capabilites in a bad way. also like zombie said cornering will be less stable. So I went back to dealership and said "Dude you sold me a front tire for the rear of my scoot" They apologized many times and ordered me the correct tire direct from Kymco.
Re: Front use only?
« Reply #6 on: July 10, 2012, 10:18:18 PM »
Rub it in... Tell them your dog borrowed the scoot for a beer run, and he wiped out on the first corner. No beer! No dog! No future business!
Re: Front use only?
« Reply #7 on: July 11, 2012, 01:53:37 AM »
Yeah! rub it in! get some chopped barbeque from the diner, show em' to Dunlop and tell them it's your dog....
Glenn
Re: Front use only?
« Reply #8 on: July 19, 2012, 08:39:34 PM »
Got a call from dealership yesterday,My correct rear tire had arrived. They installed and balanced it and it feels alot better on the road now.Better braking and tighter cornering. Now the qwest for more speed begins.Alot of info on this forum so I got to read,read,read and take notes.Thanks everyone for the advice! ;D
Re: Front use only?
« Reply #9 on: July 19, 2012, 11:31:51 PM »
Welcome aboard Glenn. We're all here to help.
In fact... we have already saved your life once., so you owe us. One day you may get a call, and we expect you to answer that call... Sleep tite!
