Did you miss your
activation email
Scooters - 50cc
Stripped clutch nut...
3
Topic: Stripped clutch nut... (Read 4806 times)
acrab78
Full Member
July 08, 2012, 11:38:59 PM »
Had a hard time getting everything back together after replacing my clutch springs and apparently stripped my clutch nut...
http://www.racingplanetusa.com/clutch-m28x1-minarelli-p-15546-1.html?cPath=2_2416_13596&sessID=b665c110af6cf9d4fcf15ce4c1273ce3
Didn't know it was bad till I started having issues when riding. It would start to die after running when getting to a stop sign or traffic light unless I would give it gas and apply the brake to keep rpms up... Worried I took the cvt cover off
acrab78
Full Member
Re: Stripped clutch nut...
July 08, 2012, 11:54:54 PM »
Oops posted too soon...
Took the cover off and the stripped nut blew off pow!!! Torque spring sprung.
So have to get a New one of those... Is this common?
Also in the torque spring are there two plastic pieces or just the one? I had one like a sleeve cap that I had on the top of the spring. Maybe it was supposed to very on the bottom??? Top being the outside close to the clutch.
Nother sure if I lost a piece the first time I put in the new spring....
Thanks!
undead primate
July 09, 2012, 12:13:11 AM »
...ouch!!!...
..no, this is not common...
plastic piece?? inna clutch??...
..i know of no such animal..
..pics
acrab78
Full Member
Reply #3 on:
July 09, 2012, 12:55:00 AM »
The stock one I have looks like this but more basic ( no bearings)
http://www.racingplanetusa.com/twist-control-naraku-racing-torque-spring-peugeot-piaggio-kymco-china-4stroke-p-4214-1.html?cPath=2_2416_2630&sessID=b665c110af6cf9d4fcf15ce4c1273ce3
Not sure if I need this one?
http://www.racingplanetusa.com/torsion-control-malossi-plastic-torque-spring-seat-p-2792-1.html?cPath=2_2416_2630&sessID=b665c110af6cf9d4fcf15ce4c1273ce3
Will try posting a pic of mine.... Still all layed out
undead primate
Reply #4 on:
July 09, 2012, 01:01:49 AM »
..okay, i thot you meant oem clutch..
..so, the big 39mm hex nut, AND the clutch bell nut both came off??
undead primate
Reply #5 on:
July 09, 2012, 01:10:48 AM »
...from looking at the pic of the malossi, it should go next to the torque driver pulley, inside the existing spring's seat...
acrab78
Full Member
Reply #6 on:
July 09, 2012, 01:16:53 AM »
The clutch bell nut is fine when I was taking it off the big thin nut under the clutch bell is stripped and popped off.
Trying to post a pic of it... My pic is too big.
Peters
In Glock I Trust
Reply #7 on:
July 09, 2012, 01:28:10 AM »
Use Photobucket.com to post pics. Free to use
Is the nut striped or the threads on the clutch? Or both?
*2001 ZX-50 beater
acrab78
Full Member
Reply #8 on:
July 09, 2012, 01:38:09 AM »
Pic try
undead primate
Reply #9 on:
July 09, 2012, 01:41:10 AM »
..spring looks okay, and should be as long as it isnt bent....should still stand straight...
acrab78
Full Member
Reply #10 on:
July 09, 2012, 02:19:25 AM »
Spring is good. Dont know if that piece should be on top or bottom when putting back together though. Had it on top... I think, it all shot out cause of the stripped nut..
Guess I will order a couple of these
Only one I could find but I know they will take forever to get it...
undead primate
Reply #11 on:
July 09, 2012, 02:21:50 AM »
..well, dang...you should not need but one!!!
..aannd, i'm pretty sure it goes next to the pulley...
Peters
In Glock I Trust
Reply #12 on:
July 09, 2012, 02:26:51 AM »
Quote
Me too
Yeah you only need one. If it comes off again something else is wrong. I assume the threads are ok???
*2001 ZX-50 beater
You never know do ya!
Close enough to get the idea!
Reply #13 on:
July 09, 2012, 02:33:22 AM »
Quote from: acrab78 on July 09, 2012, 01:38:09 AM
Pic try
That is the OEM part. It is NOT a ball bearing dampener. The piece you have goes on the pulley side. The Yellow Malossi plastic piece goes on the clutch side. The piece you have is to keep the spring from coiling into the pulley sleeve.
undead primate
Reply #14 on:
July 09, 2012, 02:38:10 AM »
..i did not know that...
Back
