Author Topic: poor performance  (Read 3143 times)
biggazmo
  • slowly going forward
poor performance
« on: July 09, 2012, 08:20:14 PM »
57 reg ag50 , cdi cut , smooth boss , 102.5 main jet , k+n filter , 5.5 rollers , new exhaust = poo uphill and slow acceleration !
2007 AG50 , smooth boss , k+n , cdi cut , sports silencer , 1500 springs , 5.5g rollers
Kernow70
Re: poor performance
« Reply #1 on: July 09, 2012, 08:51:23 PM »
What pipe is it. Your main jet seems a little big in my humble opinion. Try a 95.
biggazmo
« Reply #2 on: July 09, 2012, 08:57:59 PM »
Its a sports pipe . no brand really but sounds good . went from stock 82jet to 85 , advised locally on a102.5 ?
Kenho21
« Reply #3 on: July 09, 2012, 09:14:44 PM »
Sounds like your jet is way too big
streido
« Reply #4 on: July 09, 2012, 09:21:50 PM »
Yup too rich prob. Check the plug and i bet its all black and sooty.
Depending how black it is ypu will have to judge how much to rejet down which means buying a selection of jets and plugs and going thro them till it runs well and the plug reads good.
Chaos is my co-pilot.
biggazmo
« Reply #5 on: July 09, 2012, 09:27:54 PM »
I have ordered a 1500 torque spring and a selection of clutch springs . ill buy a 95 main jet tomorrow .
Kenho21
« Reply #6 on: July 09, 2012, 09:29:38 PM »
Quote
It's crazy how much jet sizes can differ too. Anytime someone standardizes the jet size with a certain setup I can almost guarantee it won't be right, aside from the de-restricting.
When I bought an 85cc kit from Scootertronics they said a 95 jet was what I should use with my specific setup, since then I've installed a 72cc kit instead and I have a 105 that's in right now that's running lean, about to go up to a 110 or higher.
Kenho21
« Reply #7 on: July 09, 2012, 09:30:31 PM »
IMO a set of jets is the way to go...
biggazmo
« Reply #8 on: July 09, 2012, 09:36:24 PM »
Would an oversized jet affect acceleration ?
Kenho21
« Reply #9 on: July 09, 2012, 09:39:06 PM »
I would think it would affect acceleration, top speed and midrange depending on how oversized it was. I know when I had a 95 in with my setup it wouldn't go above 15mph because it was so starved. Seems like the opposite would be possible as well.
streido
« Reply #10 on: July 09, 2012, 10:21:41 PM »
Yes if the jetting is not right it will affect acceleration, overall power and uphill speed too.
biggazmo
« Reply #11 on: July 09, 2012, 10:23:33 PM »
Ill try a 95 tomorrow while i wait for clutch springs to tour the globe on way to me
streido
« Reply #12 on: July 09, 2012, 10:58:43 PM »
Im in Glasgow and i reckon ive narowed mine down to a 94-96 after months of trial and error so you may luck out on the 95 jet. No 2 scoots are ever the same tho, too many variables, but you never know it may be there or there abouts.
Have you checked to see how the plug thats in now looks?
biggazmo
« Reply #13 on: July 10, 2012, 07:08:54 AM »
No not checked plug yet . i thought 102.5 was a bit big.......
streido
« Reply #14 on: July 10, 2012, 08:02:44 AM »
Mine ran with a 102 in it, even ran with a 110 in it too but it was too rich for me and i had the same symptoms you described. Just be sure to keep an eye on the plug once you chamge the jet out, youre going to need a new plug now to be sure since the one you jave in mow will be blackened and you wont be able to get a reading off it now from the new jet.
