Author Topic: Hello I am looking for some troubleshooting advice  (Read 2212 times)
drjazz
« on: July 10, 2012, 07:31:44 PM »
I am trying to figure out why my scooter won't start.  When I press the ignition I hear a whirring sound but the engine is not turning over.  Might it be a broken starter moter?  I really have no clue at this point and I am asking for help/advice.
Thanks,
Ed
thebatman
Re: Hello I am looking for some troubleshooting advice
« Reply #1 on: July 10, 2012, 07:38:17 PM »
My scooter has done this as well...
It does not correct the 2nd time you press the switch?
Either battery is to low OR the starter bendix is going...
I would charge the battery 1st though and see if that corrects anything.......
"THE BAT"MAN...
Says:
Jim Moore
« Reply #2 on: July 11, 2012, 12:41:28 PM »
Out of curiosity, can you kick-start it?
juice
« Reply #3 on: July 11, 2012, 12:47:35 PM »
You should be able to kick start it if it is on the center stand , kill switch off , key in on position and the brake handle depressed . Good luck .
« Last Edit: July 11, 2012, 07:24:49 PM by juice »
drjazz
« Reply #4 on: July 11, 2012, 07:11:39 PM »
Is the starter bendix the same as starter clutch?  Also I have removed the two bolts holding the starter motor but I am not able to just pull it out, why not?  And is the bendix built into the starter motor?  Or is it located elsewhere?
No to your question, it just keeps whirring everytime.
drjazz
« Reply #5 on: July 11, 2012, 07:13:04 PM »
So far the kick start ain't happening.
drjazz
« Reply #6 on: July 11, 2012, 07:14:04 PM »
You should be able to kick start it if it is on the center stand , kill switch off , key in on posirion and the brake handle depressed . Good luck .
No luck with kick starting.
drjazz
« Reply #7 on: July 11, 2012, 07:57:06 PM »
