Author Topic: Did some work on scoot today  (Read 4107 times)
streido
Re: Did some work on scoot today
« Reply #15 on: July 11, 2012, 11:10:47 PM »
Quote
Checked my plug today the end was a little white but not to bad
When doing a plug chop you want to see how the insulator looks, you dont go by the colour of the metal the tip that bends over the
tip. you want the white insulator to turn a nice light brown/tan colour. You will want to look deep down into the hole to look at the bottom of the insulator and see if theres a brown ring around it. I thought it was the tip you went by too till Word squared me upon it.
If you cant see down far enough to the bottom of the insulator you need to chop off the threaded part with a hacksaw to get a good look, like this.......thats why its called plug chops i guess?
http://www.mopedarmy.com/wiki/Plug_chop
http://www.roost.si/tech/How%20to%20properly%20read%20the%20carburettor%20jetting.pdf
« Last Edit: July 11, 2012, 11:12:45 PM by streido »
Chaos is my co-pilot.
« Reply #16 on: July 12, 2012, 02:22:55 AM »
Damed it all .going back to stock box and 82 jet .found gas in my oil. and im fouling out plugs.
« Reply #17 on: July 12, 2012, 10:46:27 AM »
..wh-wh-what??
streido
« Reply #18 on: July 12, 2012, 11:24:44 AM »
..wh-wh-what??
My thoughts exactly.........i was too scared to ask tho  :o
« Reply #19 on: July 12, 2012, 01:14:17 PM »
ok went back to stock . But what did I do wrong scoot runs fine when on kick stand then when I let up on the brake it whats to stal out. ya I know I should of touched it. lol  what might it be now.
« Reply #20 on: July 12, 2012, 06:10:06 PM »
Idle mix??
« Reply #21 on: July 12, 2012, 09:30:05 PM »
Idle mix??
as long as I had the scoot I never played with the idle screw. I went to push the back brake by hand down by the back tire. and i got a elec shock what hell. I did take the elc. starter of the bike but should I ground the wire to smoething or can I just unplug it.
« Reply #22 on: July 12, 2012, 09:33:32 PM »
You Have to attach the green wire to the engine. It wont run without it. The red you just tie back to itself.
« Reply #23 on: July 12, 2012, 10:04:42 PM »
mmm ya I thought so ill give it a shot.......
« Reply #24 on: July 12, 2012, 10:10:39 PM »
The reason it runs with the brake on is the light makes a circuit to ground when the light is on. The engine was using that ground to run. When you let off the brake no more ground/no more run
« Reply #25 on: July 13, 2012, 01:07:34 AM »
..dang blue...gotta call you "sparky" now....
« Reply #26 on: July 13, 2012, 02:21:39 AM »
the scoots back and everything is ok again. next time I try something new I give you guys permission to come and hunt me down and beat me like a no good step child.
« Reply #27 on: July 13, 2012, 02:26:40 AM »
..okay...one of us surely will!!!
                     8)
« Reply #28 on: July 13, 2012, 06:02:25 AM »
Blue pills in the morning... Red at night... Yellow when you want to "fix" the scooter.
« Reply #29 on: July 13, 2012, 11:43:21 AM »
lmfao!!
