Author Topic: looking for a good carb  (Read 4186 times)
stljimmy
« on: July 11, 2012, 04:25:50 AM »
I talked with Josh from the scooter garage today about carbs since my s9 still isnt running right after I put a top end on as Carver's scooter shop said.  He sent me a couple of links and I want to know opinions on best bang for the buck aftermarket carbs.
Here is the Malossi 19mm carb. Bolts right on but is $163.  A german website had it for $123 but says they cannot sell to USA.
http://www.racingplanetusa.com/carburetor-malossi-phbg-19mm-kymco-sf10-p-314-1.html?cPath=2_22_140&sessID=dd2b2938bea5c9f51cf1c66bad9ce73f&shop_ID=1&sessID=dd2b2938bea5c9f51cf1c66bad9ce73f
Here is the Dellorto that also bolts right up.  Of course they are out of stock.
http://www.racingplanetusa.com/carburetor-dellorto-175mm-main-p-598-1.html?cPath=2_22_140&sessID=dd2b2938bea5c9f51cf1c66bad9ce73f
I plan on getting a BBK in the future so I need to make sure I wont out grow it. You guys who run the Arreche and others, how do you get it to bolt up?
Current toys include 08 Super 9, 78 Columbia Commuter, 99 Yamaha Blaster, 82 Yamaha YZ490, 04 SRT-4, 94 F150, and a quick John Deere 70
Peters
  • In Glock I Trust
Re: looking for a good carb
« Reply #1 on: July 11, 2012, 10:48:45 AM »
I assume you're talking about the 19mm Malossi carb kit right? If so that is a Dellorto carb too. Malossi just puts it in the kit.
Dellorto 19mm is an awesome carb. I couldn't be happier with my Dellorto/Malossi kit. Not sure about Arreche. Not that they're bad, I think they're decent. Just never seen anyone with one. IMO the carb is the last place you want to skimp.
*2001 ZX-50 beater
stljimmy
« Reply #2 on: July 11, 2012, 05:20:23 PM »
Yes, it is the Malossi carb kit. Im glad to hear it works good on your Peters.  I will feel a lot better about spending the money on it. To bad I can't buy it from http://www.sip-scootershop.com/main/base/Results.aspx?t=1611028&d=(max,sco)&a=1&sort=0 where it is $45 cheaper ???
Areomyst
  • Scootin' America!
« Reply #3 on: July 11, 2012, 05:56:21 PM »
I, along with several others buy parts from them all the time.  Wonder what the issue is?
~Josh
stljimmy
« Reply #4 on: July 11, 2012, 06:55:39 PM »
~Josh
It will not let me add it to the cart.  It says "Unfortunately we are not authorized to deliver MALOSSI parts to your country. We recommend you to take the suggested alternative.
$117.77"
Areomyst
  • Scootin' America!
« Reply #5 on: July 11, 2012, 09:30:45 PM »
PM sent.
~Josh
stljimmy
« Reply #6 on: July 28, 2012, 09:51:22 PM »
Josh hooked me up with the Mallossi/Dellorto carb.  The manual that came with it is kind of vague. I have a few questions about the install. Do I leave on the part that screws onto the top of the carb where my middle finger is? If it removed how do I get it off? Do I have to premix or is there a spot on the carb for the oil injection? If I do premix I found a write up from vdubn that will help out with the removal of the pump and all of the parts. Does anybody have a pic of good install places for the choke?
Areomyst
  • Scootin' America!
« Reply #7 on: August 04, 2012, 03:56:24 AM »
The carb should have come with two cables.  One is a choke cable, and the other goes to the throttle cable "splitter".  You can use the existing cable (that's on the bike) but getting the cap off can take a bit of messing around.  There's a metal circlip that holds it onto the end of the cable.  You can get it off with a couple of hook picks and some patience.
It's better/easier just to swap out the cable.
Cheers!
~Josh
« Reply #8 on: August 16, 2012, 09:36:05 PM »
..heyyy..yeaahhh...
..what's the link to that carb??
                   ;D
stljimmy
« Reply #9 on: August 16, 2012, 09:44:27 PM »
..heyyy..yeaahhh...
                   ;D
This is the link to the carb I bought. I couldnt buy it directly from the site but Areomyst hooked me up with it and a ton of tech support.  Everything is on except I am looking for a place to hook up the oil injection.  The directions that came with it are vague. I am thinking that I remove the silver tab next to the choke cable on the bottom pic?
« Reply #10 on: August 16, 2012, 09:46:27 PM »
..thanx jimmy!!
..is there no place on the intake for it??
Peters
  • In Glock I Trust
« Reply #11 on: August 16, 2012, 09:54:18 PM »
Say what?
*2001 ZX-50 beater
stljimmy
« Reply #12 on: August 16, 2012, 10:01:06 PM »
YW. I do not see one but there is a vertical tab that is close to the intake.  I believe there are 3 tabs that can be removed. 2 are across from each other in the slide area, and one is that vertical that is close to the intake.
Peters
  • In Glock I Trust
« Reply #13 on: August 16, 2012, 10:07:36 PM »
You mean those round plugs?
*2001 ZX-50 beater
stljimmy
« Reply #14 on: August 16, 2012, 10:22:47 PM »
Yes. I havent messed with any of them in case they are not supossed to come out? I am hoping that one pops off and the injection will plug in.
